Quick throttle body question Need quick response.
Old Feb 17, 2004 | 05:12 PM
Jdmbsixteen's Avatar
Default Quick throttle body question Need quick response.
I just bought a str throttle body and am Installing it as we speak. I removed my old tb and put the str on and put all the hoses back where they were. My problem: When I go to start the car it cranks then shuts off. If I crank the car on and press the gas pedal it starts to run but as soon as I release gas pedal it shuts off again. No codes yet I had to adjust the throttle cable to get the pin in the throttle body. Now I just can't get it to idle and stay on.
Old Feb 17, 2004 | 05:15 PM
Default Re: Quick throttle body question Need quick response. (Jdmbsixteen)
When the gas is not being pressed the throttle plate should remain fully closed or should it be open a little?
Old Feb 17, 2004 | 05:16 PM
Convoy's Avatar
make sure everything is on right, if nothing works then i would try to put my stock one on and see what happens
ps: what TB were u using before
make sure the TPS has the right voltage
Old Feb 17, 2004 | 05:20 PM
Default Re: Quick throttle body question Need quick response. (ConvoyPMR)
Where do the throttle nuts have to be all the way on the end. The car will not even Idle
Old Feb 17, 2004 | 05:22 PM
Ricey McRicerton's Avatar
Sounds like your TB isnt open at all at idle. Try adjusting your idle screw so that it will at least run. Adjust down to where your idle should be once you get it started.
volts are correct checked them with vafc.
Old Feb 17, 2004 | 05:31 PM
EGtoDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ConvoyPMR &raquo;</TD></TR><TR><TD CLASS="quote">
make sure the TPS has the right voltage</TD></TR></TABLE>
also check the adjustor screw, they owned my *** for awhile, damn gremlins..
Old Feb 17, 2004 | 06:09 PM
Default Re: Quick throttle body question Need quick response. (EGtoDC2)
bump still no luck I checked the screw and the voltage both are good. I start the car without the throttle body on and it ran fine.... what am I doing wrong. It just starts then stops.
Old Feb 17, 2004 | 06:30 PM
come on guys.
Old Feb 17, 2004 | 06:58 PM
Is the throttle plate suppossed to be completely shut when the car is idling?
Old Feb 17, 2004 | 08:16 PM
XxslayerxX's Avatar
It should look closed when it is at idle. This is a pic of mine at idle
What does your car do when you start it?
Old Feb 17, 2004 | 08:45 PM
bushfreakz's Avatar
reset the sensor maybe
Old Feb 18, 2004 | 08:28 AM
Default Re: (bushfreakz)
What do you mean reset the sensor?
Old Feb 18, 2004 | 08:30 AM
nerdsports's Avatar
Default Re: (Jdmbsixteen)
does the STR have an idle adjusting screw? how about all the air passages used to let it idle correctly? seems like theres no air getting through at all.....
STR Instructions......
http://www.strspeedlab.com/Inst/TB/tbc.html
Old Feb 18, 2004 | 08:34 AM
mattssi's Avatar
Default Re: (n3rdsp0rts)
Yeah, adjust the idle adjuster screw if there is one, there should be? I believe you turn it clockwise to adjust the idle up, and counter for down! This should do it!
Old Feb 18, 2004 | 09:47 AM
Convoy's Avatar
also compare them
Old Feb 18, 2004 | 07:47 PM
I fixed it I wasn't getting an accurate reading from the map sensor. Thanks for the help guys.
Old Feb 18, 2004 | 07:54 PM
Convoy's Avatar
cool, good luck
ps: i'm still looking for that IAC.LOL!!!!!!
muddmonky
Dec 22, 2012 05:36 PM
95_red_dc
Sep 11, 2006 09:47 PM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
Initial DA6
Aug 29, 2002 03:24 PM
