Mini-me ppl i need help
Old Feb 16, 2004 | 05:26 PM
96cpe's Avatar
Default Mini-me ppl i need help
Wll i finished it up today and i'm having a problem. I have 1 cel wich is 14, the i dle air controll valve. But that is not the problem, the car is missing pretty bad. We tried adjusting the timing a few times, btw wich mark is tdc? is it the white or the red? We tried them both and still that damn problem, the miss. I don't want to drive it and my winter car needs a water pump, wich isn't a few hour job, it's a mucery mystique.
I NEED HELP ASAP!!
Thanks
Pat
Old Feb 16, 2004 | 06:35 PM
ej1 pilot's Avatar
Default Re: Mini-me ppl i need help (96cpe)
bump for a HT member in distress
Old Feb 16, 2004 | 06:45 PM
Civiclx's Avatar
Default Re: Mini-me ppl i need help (CXinthemaking)
damn dude if you set TDC to the red mark you are hella off and you have a chance you could be smacking those pistons with the valves, i would check to see if tdc is the white mark first and foremost, then get yourself a timing light and set the igntion timing. Code 14 is the least of your worries right now
Old Feb 16, 2004 | 06:52 PM
ViVaLaLude00's Avatar
Default Re: Mini-me ppl i need help (Civiclx)
good luck man i did the mini me 2 weeks ago an mine has a bad idle to... u might have to repin your iacv check to see if they are in the right pins
Old Feb 16, 2004 | 07:27 PM
Civiclx's Avatar
Default Re: Mini-me ppl i need help (civic2nr97)
did u change out the wiring harness? also take off that iacv and clean the screen with carb cleaner
Old Feb 16, 2004 | 07:46 PM
nub's Avatar
nub
white is tdc. if you went red your way off. put it tdc and look at the cam gear and see if the up arrow is staight up and the marks at 3 and 9 o-clock are parallel with the upper surface of the head (up arrow on stock cam gear only). also check and see if at tdc the rotor in the distributor is pointed at the no.1 terminal on the dist. cap. distributor could be 108 out.
Old Feb 16, 2004 | 08:33 PM
ekb18cCivic's Avatar
Default Re: Mini-me ppl i need help (nub)
well if it is throwing an IACV code.. did you clean the valve?? my friends car seemed to be miss firing anf we just cleaned out the IACV and it stopped.. try it.. and more importantly fix your timing problem you created.... you dont wanna be replacing valves
Old Feb 16, 2004 | 08:40 PM
Civiclx's Avatar
Default Re: Mini-me ppl i need help (ekb18cCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic &raquo;</TD></TR><TR><TD CLASS="quote">well if it is throwing an IACV code.. did you clean the valve?? my friends car seemed to be miss firing anf we just cleaned out the IACV and it stopped.. try it.. and more importantly fix your timing problem you created.... you dont wanna be replacing valves </TD></TR></TABLE>
yeah screw the IACV that can wait, as i stated earlier, dont mess up those valves because you "think" you got the timing right.
Old Feb 16, 2004 | 08:51 PM
sethm's Avatar
I had a problem like that when I did the swap. Give the car some time to warm up so that it will not idel so high then check your timming.
slammed_98ek
Jun 12, 2010 09:07 AM
G2Crash
Mar 10, 2005 12:31 AM
Jaydeep
Apr 28, 2004 07:15 PM
Mr. 1582
Oct 12, 2003 07:01 AM
