how can i make a sohc greddy kit fit my new b18c5?
Old Feb 16, 2004 | 02:52 PM
r1lorenzini's Avatar
Default how can i make a sohc greddy kit fit my new b18c5?
getting a swap next motnh and id like to keep and use my greddy kit can i?
Old Feb 18, 2004 | 08:19 AM
jdm_boost's Avatar
Default Re: how can i make a sohc greddy kit fit my new b18c5? (r1lorenzini)
all you have to do is get a turbo manifold for the motor. everything else should fit the same. make sure you buy one that fits your turbo size
Old Feb 18, 2004 | 08:24 AM
Chillinit's Avatar
Default Re: how can i make a sohc greddy kit fit my new b18c5? (jdm_boost)
the manifold should fit...I'm putting a b16 manifold on my gsr...don't see why the flanges woudl be different....
is the kit intercooled?? if so..u might need to redo some charge pipes...but everthing elso should be ok.....oh...fuel managment..
Old Feb 18, 2004 | 09:05 AM
JalopySiR's Avatar
O.K. first off, with some drilling, the SOHC manifold will fit on DOHC engines. Secondly, you DO NOT want to put a TD04H-15G on a B18C5. If you do not know why, then you shouldn't be turboing anything.
Old Feb 18, 2004 | 10:50 AM
Chillinit's Avatar
Default Re: how can i make a sohc greddy kit fit my new b18c5? (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">the manifold should fit...I'm putting a b16 manifold on my gsr...don't see why the flanges woudl be different....
is the kit intercooled?? if so..u might need to redo some charge pipes...but everthing elso should be ok.....oh...fuel managment.. </TD></TR></TABLE>
my bad..i though it was a Dohc kit...
Old Feb 18, 2004 | 10:58 AM
Egg-weezy's Avatar
the charge pipe on a SOHC kit is different, the I/C is the Same. You will need to buy a new Manifold for sure. The down pipe might need some modification. Other than that your good to go......except. Why would you want to boost the Type-R engine? doesn't that run higher compression Pistons?
Old Feb 18, 2004 | 11:39 AM
DaX's Avatar
DaX
Loved
Community Favorite
SFP makes a manifold that will work for you...used to have one but I sold it.
Old Feb 18, 2004 | 12:28 PM
psileepR's Avatar
New User
Default Re: how can i make a sohc greddy kit fit my new b18c5? (JalopySiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JalopySiR &raquo;</TD></TR><TR><TD CLASS="quote">O.K. first off, with some drilling, the SOHC manifold will fit on DOHC engines. Secondly, you DO NOT want to put a TD04H-15G on a B18C5. If you do not know why, then you shouldn't be turboing anything.</TD></TR></TABLE>
haha wow harsh. im wondering when he was spool the tiny thing. 2k-2.5k? For a good low end that kit would rock on your car but it will quickly run out of steam.
gl
ps. the greddy kit on my d16y8 gets full boost (8psi) by 3.8k i can only imagine an itr.
Old Feb 18, 2004 | 12:57 PM
BoostedSi's Avatar
Default Re: how can i make a sohc greddy kit fit my new b18c5? (psileepR)
sell that kit and get something else. that snail would be damn small for it
Old Feb 18, 2004 | 03:07 PM
Default Re: how can i make a sohc greddy kit fit my new b18c5? (BoostedSi)
holy crap didnt know there was so many turob gods in here hahah jk wel it was just a thought guess i will sell it when i get the swap npo harm no foul thanks alot folkers
Old Feb 18, 2004 | 03:17 PM
MikeMAN's Avatar
so very true! however, his car would be much quicker with it ON than off...it wont hurt the top end at all..
however as Jalopy has mentioned, if you can sell your current kit, get something with a little larger turbo. If I were you, i would look for the 18g turbo + DOHC blue box + injectors(if ur just lookin for some basic fun powaH), however you might even need more fuel than that due to the higher compression...might be better off getting a different kit altogether.
mike
Old Feb 18, 2004 | 03:36 PM
mogz's Avatar
Default Re: how can i make a sohc greddy kit fit my new b18c5? (MikeMAN)
I have a 18g with a 11psi actuator for sale if youre interested. check out my link:
https://honda-tech.com/zerothread?id=771648
Old Feb 18, 2004 | 03:38 PM
ProEater's Avatar
Default Re: how can i make a sohc greddy kit fit my new b18c5? (mogz)
heres what you do: buy a dohc manifold and 18g turbo (gsr/si greddy kit), then re-use the rest of you current setup
Old Feb 18, 2004 | 04:25 PM
MikeMAN's Avatar
Default Re: how can i make a sohc greddy kit fit my new b18c5? (ProEater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProEater &raquo;</TD></TR><TR><TD CLASS="quote">heres what you do: buy a dohc manifold and 18g turbo (gsr/si greddy kit), then re-use the rest of you current setup
you obviously didn't think of fuel management did you? increased displacement, higher compression, bigger turbo......
mike
btw: he doesn't need to buy a DOHC mani
Old Feb 18, 2004 | 05:25 PM
JalopySiR's Avatar
Pretty much NONE of the SOHC kit will work with the DOHC turbo/engine i.e. downpipe=nope, turbo elbow=nope, blue box=nope, charge piping=with mods maybe. Your best bet is to sell the SOHC kit. Also, I'm really not sure if it wouldn't hurt the top end. I'm sure the added low end torque would be nice, but having a type R motor, which usually has a great header attached, trying to expel its exhaust gasses through a dinky-*** 8cm2 turbine housing is not the best thing for power... boost is just compounding that problem.
Old Feb 20, 2004 | 06:33 AM
Egg-weezy's Avatar
by the way you can make anything work as long as you know how. SOHC turbo parts can be used on a Type-R. maybe not all of it, but with some modification you CAN use those parts.
super 16G or T3/T4 turbo kits(bigger turbo) or All motor (type-r all motor...can't go wrong.)
etmoron
Sep 8, 2003 08:21 AM
InTeGrA B18b1
Dec 20, 2002 04:00 PM
ATgrills.com
Sep 3, 2002 09:48 PM
prjctCIVIC
Jul 22, 2001 10:59 PM
