Aeromotive pump placement
Old Feb 16, 2004 | 02:18 PM
9seccivicsi's Avatar
Default Aeromotive pump placement
i am feeling kinda unsafe were i have my pump placed now, i was wondering were do most people place there aeromotive pumps under the car. I had mine by the sitting near the driverside rear suspension and it seemed unsafe.... could some one post some pics of were u mounted ur pump and how it was mounted? thanks
Old Feb 16, 2004 | 02:52 PM
12 oz.'s Avatar
Default Re: Aeromotive pump placement (30psiallday)
FFGeoff's car
Old Feb 16, 2004 | 05:12 PM
GRTechnologies's Avatar
lower than the tank
Old Feb 16, 2004 | 06:13 PM
DaveF's Avatar
on a car i built over the summer.
here are more pics.
https://honda-tech.com/gara...=1249
Old Feb 16, 2004 | 06:26 PM
Jay Dirt's Avatar
Default Re: Aeromotive pump placement (2.2Lcivic)
i drove geoffs car from NJ to AZ with it hanging like that and i had no problems whatsoever and to be honest, it never dawned on me that it was hanging there, not that i was offroading or slamming debris... perhaps i should have been a little more aware though
Old Feb 17, 2004 | 04:17 AM
turbologist's Avatar
Did you use any rubber isolaters for vibration damping on the pump? If so, where did you get em ' from?
Old Feb 17, 2004 | 10:40 AM
Kwuaymaikrup's Avatar
Default Re: Aeromotive pump placement (Turbologist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbologist &raquo;</TD></TR><TR><TD CLASS="quote">Did you use any rubber isolaters for vibration damping on the pump? If so, where did you get em ' from?</TD></TR></TABLE>
I just cut some 1/2" spacers out of some extra 3/8" hose I had laying around.
Old Feb 17, 2004 | 10:49 AM
Kataku2K3's Avatar
Default Re: Aeromotive pump placement (Kwuaymaikrup)
Tho you are working with an Aeromotive pump this is where I mounted Duc's Magnaflow EFI 600 on his EJ6...
Old Feb 17, 2004 | 11:14 AM
Soon_2b_evil's Avatar
Default Re: Aeromotive pump placement (Kataku2K3)
interesting where did you get that sump from?
Old Feb 17, 2004 | 11:56 AM
Default Re: Aeromotive pump placement (Soon_2b_evil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil &raquo;</TD></TR><TR><TD CLASS="quote">interesting where did you get that sump from?</TD></TR></TABLE>
Looks like a Moroso.....
Old Feb 17, 2004 | 02:40 PM
99blackcivicSi's Avatar
Summit has them for like 60 bucks from Comp engineering
Old Feb 17, 2004 | 03:39 PM
which is better having a sump or some sort of siphon?
Old Feb 17, 2004 | 03:43 PM
Default Re: (30psiallday)
i prefer a sump myself
Old Feb 17, 2004 | 04:06 PM
does the sump mees up the refuel light... like it comes on whe in the tank is at 3/4 full or something like that?
Old Feb 17, 2004 | 04:10 PM
why would it? your still using the stock plunger little thing, yeah if your low on gas it will spill out of the sump back into the tank and you will starve it for gas, but don't worry about it just keep the tank over 1/4 tank on the street.
Old Feb 17, 2004 | 04:21 PM
Kataku2K3's Avatar
Default Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">i prefer a sump myself</TD></TR></TABLE>
Me too, kind of off the subject but it is actually a CE sump... We originally just ran a bottom feed straight off the tank but we were developing surging and leaning out problems top end (when the pump just couldn't get any fuel, sloshing)... This always happened if we even got anywhere close to 3/4 of a tank or less... You may or may not have seen in some other fuel sump posts so I'll just say it again... When we installed the sump Scott (CrazyCompression) and I dropped the tank, had it acid tanked (stripping it to bare metal), and then cut the enitre top of the tank off... After the top was out of the way we were able to gut the stock baffle out (drilling out spot welds is always FUN), then we pounded one of the reinforcement ridges in the tank flat so that we had a nice surface to weld to (only the one above the sump plate)... But before it was welded we first drilled nine 0.75" holes (only) near the front/shallow side of the sump so that under acceleration fuel is "locked" in before it's pumped forward... Here's a pic from Sonoma last year before we figured out that bottom feeds don't work too well (as you can see we just welded a fitting into the bottom then ran a 90º off of that)... Just my $0.02 again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiallday &raquo;</TD></TR><TR><TD CLASS="quote">does the sump mees up the refuel light... like it comes on whe in the tank is at 3/4 full or something like that?</TD></TR></TABLE>
It actually allows your tank to hold more fuel, (of course not by any considerable amount, maybe a quart max) but when the light comes on your tank would have more fuel in it with the added sump than it would without (stock tank)... Not a big deal, Scott and I ran the fuel return back in the top of the tank where the factory pump would normally sit...
Modified by Kataku2K3 at 6:37 PM 2/17/2004
Old Feb 17, 2004 | 05:22 PM
Full-Race Geoff's Avatar
nice install
Old Feb 18, 2004 | 02:11 AM
MrParks's Avatar
thats preety sick .nice
Old Feb 18, 2004 | 06:52 AM
i had a siphon made it comes from the top of the tank were the original fuel pump was. I have not tried it yet but des any one think that it will work?
Old Feb 18, 2004 | 07:40 AM
Kataku2K3's Avatar
It wouldn't work with our pump, they rely a lot on gravity feed... With the MagnaFlow's you just need to remember that they aren't good at sucking but they have a lot of pushing power... For this reason we have to mount the pump really close to the same level as the sump... Our basic rule for mounting the pump is, if you can't place it at the same level or lower than the pickup feed it's probably not going to work... Again, I haven't noticed as much of a problem with the Aeromotive pumps (we mainly use MagnaFlow tho) but then again they flow a lot less... Peace
ohsnapzafingcu
Nov 17, 2013 08:20 PM
chippinpressure
Feb 26, 2011 06:26 PM
JDMCRX
Welding / Fabrication
11
Nov 28, 2006 02:30 PM
iNetForce
Feb 5, 2004 10:44 PM
