F/S Butler Tube amp TD475
4 x 75Watts RMS, Both channels driven (TRUE Power)
2 x 200Watts RMS, Mono (Bridged)
Driver Tubes- 6SL7GT x 2 Dual Triodes, Hand Selected
Tube Heaters- DC, Fully Regulated, Delayed Soft Start
Output Devices- 16 x 15Amps, Sanken (Audiophile grade)
Cooling- Massive Internal/External Heat Exchanger with quiet, Temperature-controlled Fan
Heat Exchanger 400% Oversized (Compared to original model 1500)
Frequency Response- 5Hz - 100Khz (+/- 1 dB)
Idling Current- 3.5 Amps
THD (Distortion)- Less than 0.15% (30Khz Bandwidth, Unweighted)
S/N Ratio- Better than 110dB (A-weighted)
Negative Feedback- ZERO, no global negative degenerative F/B loop (Open-Ended Design)
Tonality- Musical, Warm & Dynamic (Rivals 'All Tube', home audiophile amps)
Dimensions- 10.2" x 20.5" x 2.4"
Weight- 14 Lbs.
Color- Frosted Platinum
Tube Illumination- Internal BLUE LEDs (Trademark and Patent Pending)
hey it's a tube amp
taking offers. No skimping on me either!
mucho gracias
Weight- 14 Lbs.
hey it's a tube amp
mucho gracias
it is.
http://www.butleraudio.com
http://www.tubedriver.com
same thing.
unless you're talking about something else i don't know?
same thing.
