Code 3, check valves??
Hey guys, I think I might be having some on/off issues with my check valves.
The other day I got a code 3 on the ECU when I hit boost, the car also was on the verge of stalling. I poped out the check valves and one seemed to be getting stuck. My question is if the check valve gets stuck open would the car almost stall at idle? I guess it would run like I had a vacum leak?
Im also running 3 Check valves, could I run 4?
Also whats this Missing link I heard about? How does it hook up? Wheres the best place to get one?
This is a Greddy turbo "92-95 Civic kit" on a ZC engine, thanks
doesn't anyone realize that the Missing Link IS a check valve? The only difference is that it's made of metal and has a thicker surrounding molded to fit under your sensor. A great piece I think!
evilhatch2.0
Feb 12, 2004 09:47 PM
harryg
Sep 7, 2003 08:05 AM
