Code 3, check valves??
Old Oct 10, 2001 | 10:01 AM
CWBETB's Avatar
Default Code 3, check valves??
Hey guys, I think I might be having some on/off issues with my check valves.
The other day I got a code 3 on the ECU when I hit boost, the car also was on the verge of stalling. I poped out the check valves and one seemed to be getting stuck. My question is if the check valve gets stuck open would the car almost stall at idle? I guess it would run like I had a vacum leak?
Im also running 3 Check valves, could I run 4?
Also whats this Missing link I heard about? How does it hook up? Wheres the best place to get one?
This is a Greddy turbo "92-95 Civic kit" on a ZC engine, thanks
Old Oct 10, 2001 | 10:17 AM
newsense's Avatar
New User
Default Re: Code 3, check valves?? (CWBETB)
the missing link is a billet solution to all those pesky check valves (that sounds like a sales pitch) it works great... you can get them from importparts.com
Old Oct 10, 2001 | 03:12 PM
CWBETB's Avatar
will i be able to use a missing link on my setup though? Does it matter since Im using a ZC?
Old Oct 10, 2001 | 03:14 PM
Rob03Pro5's Avatar
Default Re: Code 3, check valves?? (newsense)
doesn't anyone realize that the Missing Link IS a check valve? The only difference is that it's made of metal and has a thicker surrounding molded to fit under your sensor. A great piece I think!
Old Oct 10, 2001 | 04:10 PM
GSRwBOOST's Avatar
Default Re: Code 3, check valves?? (Rob92SC)
Yea, get the missing link. you'll solve several problems at once... until thenext one comes up.. LOL
illusive
Nov 25, 2004 04:32 AM
evilhatch2.0
Feb 12, 2004 09:47 PM
harryg
Sep 7, 2003 08:05 AM
B17aTrbo
Aug 16, 2002 08:32 AM
filetofit
Jun 4, 2002 02:56 PM
