cam seal leaking???
It's not hard at all. Just take the valve cover off and look at the cam seal part and take the 2 top bolts off and pop it off. Do a search , has been covered plenty of times thats why you haven't gotten to many replies.
There is some grey stuff VatoZone sells, that is similar to Hondabond. I would replace it with a GE cam plug, they are fairly cheap and worth the extra few bucks. I JUST replaced mine like 2 weeks ago with an OEM unit and it was leaking again. Replaced it with a GE one 2 days ago and not a bit of a leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast »</TD></TR><TR><TD CLASS="quote">There is some grey stuff VatoZone sells, that is similar to Hondabond. I would replace it with a GE cam plug, they are fairly cheap and worth the extra few bucks. I JUST replaced mine like 2 weeks ago with an OEM unit and it was leaking again. Replaced it with a GE one 2 days ago and not a bit of a leak.</TD></TR></TABLE>
GE = golden eagle?
also, c-speedracing.com has an article on changing cams and I think it would tell u how to change the cam seal as one of the steps.
GE = golden eagle?
If you have oil on your distributor it's not because of the cam seal.
There's a seal on the distributor shaft that needs to be changed. It looks like an o-ring. In fact, I think it's called distributor o-ring.
hondaeg8
12
Aug 11, 2004 11:39 PM
