Do I need a BOV
I am currently turbocharging my 89 civic si with a ZC. I am only going to run with at the most 9 lbs of boost. My concern is wasting money on a BOV if I don't need it. Any feedback will help. Thanks
take your time and get every piece needed dont skip or try to get by without having a single piece. even if it takes another year to get all the pieces together it will be better than blowing up your car. right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MMsportsRexSi »</TD></TR><TR><TD CLASS="quote">dont try to save money building a turbo motor, unless you are saving that money to buy a new motor
That is exacty what I say.
You want a cheap hobby jerk off, you want a fast car open your walet.
</TD></TR></TABLE>That is exacty what I say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i-16zc »</TD></TR><TR><TD CLASS="quote">take your time and get every piece needed dont skip or try to get by without having a single piece. even if it takes another year to get all the pieces together it will be better than blowing up your car. right? </TD></TR></TABLE>
Agreed. do it right the first time and you will be rewarded.
why get a first generation dsm talon/eclipse BOV? Does it matter between all the company's BOV? like performance wise? or do they all just do the same damn thing, cept make a different noise?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportsCRX »</TD></TR><TR><TD CLASS="quote">why get a first generation dsm talon/eclipse BOV? Does it matter between all the company's BOV? like performance wise? or do they all just do the same damn thing, cept make a different noise?</TD></TR></TABLE>
You can pick up a used DSM BOV for around $30-$50. Most universal aftermarket BOVs start at $170 (new) and go up from there.
EDIT: if you're only running low boost then IMO it's not necessary to run a name brand BOV. They pretty much do the same thing, just some better then others.
Modified by BlueShadow at 9:37 PM 2/14/2004
I am actually looking at getting a Greddy type-S BOV. I can't find any specs for this BOV on the lowest boost this will work with. I've seen the max, 18 lbs. but no lower limit. I am not even sure I can run 9 lbs due to the MTBE in the fab. wisconsin gas. My comp. ratio now w/o turbo is around 10.2:1. Only one way to find out.
slide inside
Sep 24, 2009 08:40 PM
