At what point do you upgrade spark?
Is is related to boost? Or HP?
Planning a build of my b18c5 in the next year, aiming for 15 psi/350 hp, wondering if there is any merrit of getting an msd system or something...
most hondas run the same ignition setup....so a jdm type R with 200- 220 hp or so
same as a dx with 90hp....
so you make the choice...i think they are good for alot....but at some point the spark is going to blow out on the FI setups, even SOME NA setups need an upgrade
if you feel you need to do it. do it ..if not your probably fine....mase is right your probably fine
92HB_HB
Apr 15, 2004 12:50 PM
