Swap or turbo
Old Feb 13, 2004 | 03:16 PM
Gimpo's Avatar
Default Swap or turbo
should i put the time and money to drop a 99GS-R VTEC into my 91 LS or should i sell the motor and get a turbo?
Modified by Gimpo at 4:43 AM 2/14/2004
Old Feb 13, 2004 | 07:43 PM
Gimpo's Avatar
Default Re: Swap or turbo (Gimpo)
Old Feb 13, 2004 | 07:44 PM
ls_vtec_crx's Avatar
put the gsr head on the ls block. and then put a turbo
nah i'd to with the turbo
Old Feb 14, 2004 | 12:21 AM
smithasillin's Avatar
Default Re: Swap or turbo (ls_vtec_crx)
[QUOTE=ls_vtec_crx]put the gsr head on the ls block. and then put a turbo
that is exactly what i would do.
Old Feb 14, 2004 | 12:54 PM
B1Boosted's Avatar
From: from a lil town called none ya gatdamn business, usa
i think you will be happy with the outcome either way..i have a boosted ls hatch that i am very satisfied with the power aprox 305 whp on 13psi w/ built bottom end, but i am looking for a vtec head to throw on bc it will make more power.......is your ls built or stock
Old Feb 14, 2004 | 01:47 PM
Dyno Queen's Avatar
Default Re: Swap or turbo (B1Boosted)
ive drove this thing, ive rode in this thing, its the LS monster, if only we had a vtec head to slap on this beast, wow what kinda numbers would she make then??
sup gabe haha
Old Feb 14, 2004 | 04:19 PM
zensoku207's Avatar
you could rebuild the ls motor, then turbo it...
LS's got mad potential for FI husspower
Old Feb 14, 2004 | 04:36 PM
B1Boosted's Avatar
yeah mike....you know the ls's dont play
Old Feb 14, 2004 | 05:28 PM
Gimpo's Avatar
what is approx cost on a head swap both motors are b18s
Old Feb 15, 2004 | 10:21 AM
Dyno Queen's Avatar
not sure exactly, there is a kit out there just search for it, good luck!
-Mike
Old Feb 15, 2004 | 10:24 AM
B1Boosted's Avatar
you'll need to buy is an LS head gasket, oil lines for the vtec, and a P72 ecu and that should pretty much have you covered, then just swap out the heads
Old Feb 15, 2004 | 10:27 AM
B1Boosted's Avatar
you can also use a obd1 P30 or a chipped P28.....either one of these ecus will be fine as well
Old Feb 16, 2004 | 11:30 AM
Dyno Queen's Avatar
http://www.lightningmotorsports.com has a kit for your app.
Old Feb 16, 2004 | 12:45 PM
B1Boosted's Avatar
Default Re: Swap or turbo (Dyno Queen)
that kits a little pricy mike
Old Feb 16, 2004 | 05:21 PM
zensoku207's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B1Boosted &raquo;</TD></TR><TR><TD CLASS="quote">you'll need to buy is an LS head gasket, oil lines for the vtec, and a P72 ecu and that should pretty much have you covered, then just swap out the heads </TD></TR></TABLE>
GE makes a nice conversion kit for that set up, all u need is a vtec head and a couple fittings.
Replacing the rings and rod bolts would be a good idea too, and if u plan on swapping out possible rod/piston combo since the motors going to be torn apart.
Old Feb 17, 2004 | 10:29 PM
B1Boosted's Avatar
Default Re: Swap or turbo (zensoku207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">
Replacing the rings and rod bolts would be a good idea too, and if u plan on swapping out possible rod/piston combo since the motors going to be torn apart.</TD></TR></TABLE>true true......how much is that GE kit
Old Feb 18, 2004 | 09:11 AM
zensoku207's Avatar
it depends on where u go to get it, but its the safest and most effective conversion kit on the market IMO, worth every penny.
JDMJunior
Jul 24, 2006 06:53 AM
allmotor_dm
Jan 13, 2006 08:57 PM
Glocker
Aug 16, 2005 08:29 PM
JDubya
May 12, 2002 06:23 PM
baonest
Apr 18, 2002 04:53 PM
