is this "clocked" enough?
i know you need the oil send / return up and down, and im pretty sure i had it that way when it first fired her up, but i think shes been moving.
my question is...if i tighten them down extremely tight now, is this clocked enough or does it need to be 100% strait up and down. thanks in advance.
looks allright, you know the idea, the turbo feed looks close the manifold, if you feel like it you can try a heat reflective sleeve over the feed - steal one from a VW motor, they have tons of it or get a 30degree fitting so you can angle the feed away slightly forward. how close is the DP to the rad, in the pic looks pretty close, probably just the picture.
I cannot really tell from the angle of the picture, but a good rule of thumb is to not exceed a 15 degree angle when clocking the center housing.
FOrSfEd
Feb 1, 2004 04:33 PM
DIY_Racing
Dec 15, 2002 06:41 PM
