will 92 integra rear disc brake set up fit on my eg?
Old Feb 11, 2004 | 11:53 PM
EGcivicBoy's Avatar
Default will 92 integra rear disc brake set up fit on my eg?
thinking about buying a 92 civic hatch... and my buddy has a rear disc conversion off of his 92 integra ls.... wondering if it would fit.
anyone know? thanks
Old Feb 11, 2004 | 11:55 PM
Street Ghost's Avatar
Default Re: will 92 integra rear disc brake set up fit on my eg? (EGcivicBoy)
no, they wont fit.
88-91 Civics .. 90-93 Integras
92-95 Civics .. 94-00 Integras
i think that's how it goes in terms of some parts being interchangable.
Old Feb 12, 2004 | 02:01 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: will 92 integra rear disc brake set up fit on my eg? (93 EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">no, they wont fit.
i think that's how it goes in terms of some parts being interchangable.</TD></TR></TABLE> O know that correct for front brakes but is ittrue or rear brakes?
Old Feb 17, 2004 | 08:49 AM
IntegraXSi's Avatar
They will work... Seen it done it .. But you should need use DC Integra LCAs or some after market ones and a DC teg Rear sway bar ...
Old Feb 17, 2004 | 09:28 AM
wilsel's Avatar
Default Re: (IntegraXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraXSi &raquo;</TD></TR><TR><TD CLASS="quote">They will work... Seen it done it .. But you should need use DC Integra LCAs or some after market ones and a DC teg Rear sway bar ... </TD></TR></TABLE>
Sway bar will be a nice addition, but can you explain why he would need it to swap the brakes please? I've always heard 94-01 teg brakes only. 90-93 teg fit a 88-91 civic.
Old Feb 17, 2004 | 09:34 AM
SloCivicHMM's Avatar
Default Re: (wilsel)
arg, THIS ****, always pops up..
yes they will work!!!!!! one down side they will make your wheel track wider...by like 3mm......no biggie since alot of people fun 3mm spacers for track use etc etc
stock LCA's, stock Upper control arm, and stock compensator arm, from your CIVIC need to be used, the TA and full brake set up will work....one ebrake braket from the TEG will not line up use the CIVIC one....
Why do I know this?? I've done this before...and I have it on my car, and I've posted about it a while ago........simple as that......
Old Feb 17, 2004 | 09:35 AM
sohcvtec1995's Avatar
it will work. it is just alot of work to do. You have to take every rear brake componet off the donor car. And change it out with your stock drums. Also you have to remeber that there is this bracket on the rear axel that has to come off. You have to take off this nut (like a cv joint nut) and then two bolts. Have fun
Old Feb 17, 2004 | 09:36 AM
TeamNextGenChris's Avatar
he's right..i've done it myself before....
how many times will this be asked?
chris
Old Feb 17, 2004 | 09:37 AM
Default Re: will 92 integra rear disc brake set up fit on my eg? (92 civic VX B18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c &raquo;</TD></TR><TR><TD CLASS="quote"> O know that correct for front brakes but is ittrue or rear brakes?</TD></TR></TABLE>
and Jeremy, for the front to make DA brakes work you need TEG tie rods, and the TEG upper A arm......and you should have no problems other than the 3mm wider wheel base...
91siefcivic
Apr 4, 2011 11:30 AM
95eg-K
Oct 31, 2007 02:08 PM
Markb16a
Oct 14, 2006 01:50 PM
dem0nk1d
Mar 16, 2006 11:45 AM
