will 90-93 integra rear disc brakes and master cylinder work on a 95 civic hatch eg?????
i have a set of 90-93 gsr rear disc brakes that I was selling but now I heard that they can fit on a hatch 92-95 style eg. Is this possible cause I thought you had to use 94-01 integra rear disc brakes? just wondering if anyone has done this or knows this can be done? also the master cylinder and brake booster can that work as well? thanks
Re: will 90-93 integra rear disc brakes and master cylinder work on a 95 civic hatch eg????? (Markb1
as far as i know only the DC conversions will work, not the DA..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">as far as i know only the DC conversions will work, not the DA.. </TD></TR></TABLE>
x2
x2
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markb16a »</TD></TR><TR><TD CLASS="quote">i have a set of 90-93 gsr rear disc brakes that I was selling but now I heard that they can fit on a hatch 92-95 style eg. Is this possible</TD></TR></TABLE>
Yes. '90-93 Integra rear disc hubs and calipers will bolt up to any '88-00 Civic, '90-01 Integra, '88-91 CRX, and '93-97 del Sol trailing arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">cause I thought you had to use 94-01 integra rear disc brakes?</TD></TR></TABLE>
You thought wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">just wondering if anyone has done this or knows this can be done?</TD></TR></TABLE>
Yes. Me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">also the master cylinder and brake booster can that work as well? thanks </TD></TR></TABLE>
You don't need that for a rear disc conversion. Don't bother unless you are upsizing the front brakes as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">as far as i know only the DC conversions will work, not the DA.. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MattsGreenEG »</TD></TR><TR><TD CLASS="quote">x2</TD></TR></TABLE>
Wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16si »</TD></TR><TR><TD CLASS="quote">i heard they do fit they just need your rear lower control arm not sure double check </TD></TR></TABLE>
You don't need any arms. All you need are the hub assemblies, calipers, soft lines, rotors, pads, and a set of appropriate e-brake cables for your chassis. Proportioning valve will depend on what fronts are being used.
You thought wrong.
Yes. Me.
Wrong.
Markb16a
13
01-24-2008 05:19 PM
GSR FRONT AND REAR BRAKES 100% COMPLETE WITH EBRAKE CABLES AND MASTER CYLINDER AND BRAKE BOOSTER,+ C
TYPERman2001
10-05-2006 07:02 AM
