whats cheper allmotor/turbo setup
Old Feb 11, 2004 | 01:40 PM
allmota1.8's Avatar
Default whats cheper allmotor/turbo setup
looking for 11sec pass what would be the best way to go based of money to spend? thanks
Old Feb 11, 2004 | 01:44 PM
redboost10's Avatar
Default Re: whats cheper allmotor/turbo setup (jkjb16a)
haha, post the same poll in the all-motor forum and itll be the otehr way around
Old Feb 11, 2004 | 01:45 PM
TurboJesse
Guest
Posts: n/a
not even close...you can run 11's on a stock motor with turbo....all motor will take thousands and still not run 11's unless your in a sub 2000lb car
Old Feb 11, 2004 | 01:49 PM
redboost10's Avatar
Default Re: whats cheper allmotor/turbo setup (Mpir3)
alright once i start to think about it more than i usually think, which isnt much, i see what you mean. it would take some high compression which results in race gas everyday if its a daily driver and etc etc etc
Old Feb 11, 2004 | 01:51 PM
quikB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">not even close...you can run 11's on a stock motor with turbo....all motor will take thousands and still not run 11's unless your in a sub 2000lb car</TD></TR></TABLE>
Yeah exactly, what kind of car is this going in?
Last year JdmRicemonster pieced together a Turbo kit in his Crx, Total cost including car was like 4k I heard, and he ran 12.1 on like 9-10 psi stock motor.
If done correctly, and $ is spent wisely Turbo hands down.
My suggestion is start with a light setup, so that you can do it on Stock motor. Well say 2000lb Crx + 275 whp+ slicks+ suspension +good driver= your 11 second pass.
Old Feb 11, 2004 | 02:21 PM
allmota1.8's Avatar
Default Re: whats cheper allmotor/turbo setup (quikB18B)
its going in a crx thanks for the info so far... LS/VTEC OR B16a
Old Feb 11, 2004 | 02:59 PM
deviant1's Avatar
some people put together junk yard turbos for around $1000 and hit low 13s. turbo get my vote
Old Feb 11, 2004 | 03:21 PM
TwistedHatch's Avatar
deffinately get something 1.8 if you can........i've had a couple turbo b16's and thye put down some good hp, but horrible torque, my last turbo b16 i had to launch off the rev limiter....this was a hondata tuned motor and it ran 12.94......if a full interior 92 si......i had some pretty tall slicks though..24.5.......and the motor let go in third gear.....
Old Feb 11, 2004 | 04:10 PM
TRE_'s Avatar
turbo... but i'm biaist(spelling?)...
Old Feb 11, 2004 | 04:20 PM
spun Vtec's Avatar
Default Re: (THE_HX)
this is called cheap. https://honda-tech.com/zerothread?id=738961 no where close to 11's but maybe low 14's
Old Feb 11, 2004 | 04:47 PM
aka010010
Guest
Posts: n/a
11sec? wow. are you hatch with a swap and stripped of everything u dont need while racing? are you gunna build the motor? i believe turbo is cheaper, but not that hceap to run a 11 sec slip.
Old Feb 11, 2004 | 05:09 PM
TurboJesse
Guest
Posts: n/a
Default Re: (aka010010)
Ive raced cars that have gone 11.7 and 11.9 and i was basically dead even with both of them, they would pull one race, i would pull the next...I have a b16a, total cost of all my turbo accs. was about ~$2800...
Old Feb 11, 2004 | 07:34 PM
vtec.dc2's Avatar
you should ask the same question in all motor forum
Old Feb 11, 2004 | 08:30 PM
Kataku2K3's Avatar
Default Re: whats cheper allmotor/turbo setup (vtec.dc2)
I actually think NA is probably the cheaper way to go... Though with an FI motor you can basically take an internally stock motor, swap a turbo kit on it, and make decent power NA can be pretty cheap... If you wanna bulid a crazy setup no doubt about it FI is more expensive... Building a SP/FWD car with ~750whp in my mind to do it right will cost you ~$30-35K on the motor, EMS, and fuel system... We won't get into this because that motor should put you waaay beyond 11's... Just for a comparison David (a.k.a. Shrek) had his CRVTEC last season which was composed of a stock sleeved B20B bored to 84.50mm with JE 11.50:1 pistons, stock rods, Portflow head, Toda B's, and Hondata... Though it only made 185whp on our Mustang Dyno (you have to remember it wasn't a super high compression motor with wild cams and the like) it still managed 12.10's in his ~2300lbs. EH2... This motor costed only costed him ~$4500 which is probably a little less than a B series motor and a turbo kit... In my sig. I have Scott (CrazyCompression's) NA CRVTEC motor which should do mid 11's in a full interior EH2/3... The complete motor with ITB's ran him $7500 which I would think is closer to the price of a stock FI setup... I like NA for the instant power it has, but I LOVE BOOST... Just my $0.02
Old Feb 11, 2004 | 11:32 PM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkjb16a &raquo;</TD></TR><TR><TD CLASS="quote">its going in a crx thanks for the info so far... LS/VTEC OR B16a</TD></TR></TABLE>
turbo gets my vote. if you are trying to stay on a tight budget... have you considered just the LS without the vtec head? i think that could get you there for less total $$
dansred2000si
Oct 22, 2007 07:35 PM
autoxgsr
Jul 13, 2007 06:36 PM
jarrYd
Nov 29, 2005 10:47 PM
f@sth@tch89
Jul 23, 2003 02:04 PM
advance concepts
10
Jul 17, 2003 12:39 PM
