Vacum lines help (already searched without success)
Old Feb 11, 2004 | 01:27 PM
Blindstuff's Avatar
Default Vacum lines help (already searched without success)
I honestly have no idea how to setup my vacuum lines
From left to right lets name them 1,2,3.
Top to bottom 1,2,3.
All other turbos i have seen there is no nipple coming out of the turbo it self. Help me out, where does what conect to. Please answer it as in number X conects to Z.
Thanx for helping out!
Modified by Blindstuff at 5:15 AM 2/12/2004
Old Feb 11, 2004 | 02:28 PM
Blindstuff's Avatar
Default Re: Vacum lines help (Blindstuff)
ttt
Old Feb 11, 2004 | 06:44 PM
pornstarSR's Avatar
i only see the top turbo picture in your post....but i will try to answer
ok the nippled off the turbo housing can connect directly to the wastegate right across from it....easiest
but if you have a intercooler you will lose a couple psi of boost at the intake manifold....but if you route the wastegate line to a port on the intake manifold, the wastegate will compensate for the intercooler pressure drop and get you your missing psi....
but if you do that you have to either remove and plug the port on the turbo housing....or cap it somehow...and do it good cause thats pressure side...
Old Feb 12, 2004 | 01:16 AM
Blindstuff's Avatar
Default Re: Vacum lines help (pornstarSR)
thanx a lot...on the other side of the wastegate what goes? and where do i T off to send a line to the BOV?
Old Feb 12, 2004 | 01:38 AM
Nick7's Avatar
For BOV you need vacuum - so you need to T line there. For example one going to FPR or brake booster.
Old Feb 12, 2004 | 04:08 PM
Blindstuff's Avatar
Default Re: Vacum lines help (Nick7)
All solved, thanx for the info
Old Feb 14, 2004 | 01:28 AM
pornstarSR's Avatar
the wastegate looks like a dual port wastegate....
so block off the bottom one and run the top one only and you will be fine...
Old Feb 14, 2004 | 05:59 AM
Blindstuff's Avatar
i thought one exit was for the boost gauge...or what i just T off for that too?
Old Feb 15, 2004 | 10:21 AM
ironcheftony's Avatar
T that off to
Old Feb 15, 2004 | 12:49 PM
Blindstuff's Avatar
Default Re: (ironcheftony)
k, thanx.
b18_integra
Feb 18, 2008 04:42 PM
vladd
Nov 9, 2006 06:56 PM
skierGT
Jun 21, 2004 09:32 AM
phase12gsr
Oct 28, 2002 08:00 PM
vtecsiqt
May 15, 2002 06:55 AM
