greddy turbo kit bad idle
Old Feb 10, 2004 | 06:21 PM
WCI's Avatar
WCI
Default greddy turbo kit bad idle
ok I just installed a greddy turbo kit on a 98 gsr. when it warms up it idles way crappy though. did a comp check for the hell of it and cam up with 160 180 170 170. It is running a comptech all motor ecu (dont worry Im not going to boost with it) could this effect the idle. Any suggestions of things to check would be appreciated. thanks - josh
Old Feb 10, 2004 | 06:27 PM
WCI's Avatar
WCI
Default Re: greddy turbo kit bad idle (WCI)
no CEL's and when it is idleing ok it has 16 vac
vtekthis's Avatar
check for vacum leaks!
Old Feb 10, 2004 | 07:12 PM
grndcont's Avatar
did you butt splice the blue box in, or did you solder and tape it? make shure the mechanical advance on the ignition is set to 16* (stock). check for proper spark plug wire placement. check everything!
Old Feb 10, 2004 | 11:08 PM
WCI's Avatar
WCI
Default Re: (grndcont)
I soldiered and shrink tubed the connections and checked and gapped all the plugs. smells like it is running rich. Plugs are black, wet and smell like gas.
Old Feb 11, 2004 | 12:42 AM
slammed_93_hatch's Avatar
Default Re: (WCI)
this cars has a comptech ECu in it. i think its playing hell with the retard BLUE ***** oops BLUE bOX
Old Feb 11, 2004 | 01:54 AM
integrx's Avatar
New User
hey well yea when i start my car vac reads 16. As for the gas smell, i smell it too, i'm using the smc with 450s. Did you get sparkplugs or are you runing the stock ones? did you reset the ecu?
Old Feb 11, 2004 | 07:15 AM
WCI's Avatar
WCI
Default Re: greddy turbo kit bad idle (integrx)
I got new ngk's and unplugged the ecu to reset it. looking for a vaccum leak.
Old Feb 11, 2004 | 10:44 AM
WCI's Avatar
WCI
figured it our. everything was soldiered except the map had quik connects. It was not a good connection. runs fine now. Thanks for all the suggestions.
Old Feb 11, 2004 | 02:10 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WCI &raquo;</TD></TR><TR><TD CLASS="quote">ok I just installed a greddy turbo kit on a 98 gsr. when it warms up it idles way crappy though. did a comp check for the hell of it and cam up with 160 180 170 170. It is running a comptech all motor ecu (dont worry Im not going to boost with it) could this effect the idle. Any suggestions of things to check would be appreciated. thanks - josh
if you are using the bluebox then it was programmed for a stock ecu. Take out the all motor chipped ecu. it will only be problems.
vtecgsr98
Dec 24, 2005 11:21 AM
dynamicRacing719
Jan 17, 2005 06:15 PM
BDTURBO
Feb 24, 2003 07:19 PM
DuNkiN
Feb 26, 2002 03:15 PM
