Can air fuel ratio affect boost pressure?
Old Feb 9, 2004 | 11:58 AM
5thgencivic's Avatar
Default Can air fuel ratio affect boost pressure?
I'm trying to figure out what might cause the spiking problem I'm having. Low boost setting is fine(held rock steady at 8psi). I'm using a lovefab sst with a 35mm tial(.4bar spring), Turbo xs dual stage MBC. On the high boost setting it would go to 14psi then settle back down to 12psi. That was also around where the air fuel started to richen up from a lean spike. I'm going to try a heavier spring and am also getting retuned, but just wondered if air fuel or timing can effect it at all? Thanks.
Nate
Old Feb 9, 2004 | 12:58 PM
Default Re: Can air fuel ratio affect boost pressure? (Mase)
It holds steady on low boost. It's just the high boost setting on the turbo xs controller. I'll probably end up running a bigger spring and just use the first stage of the boost controller.
Old Feb 9, 2004 | 01:11 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">Extremely doubtful.
I would start off by disconnecting the boost controller and testing it, if it still creeps, then its most likely your slick manifold.
is it really necessarry to make fun of cody's manifolds. you just did this in another thread. it's not very professional you think?
especially when in your sig, you are trying to represent full-race
Old Feb 9, 2004 | 01:12 PM
lazerus's Avatar
Default Re: Can air fuel ratio affect boost pressure? (hybridvteceg)
Air fuel ratios in combination with low ignition timing can cause boost creep, but probably not a spike.
It's been demonstrated and a proven diagnosis of fixing the problem with a proper tune. im user Falcon GSR can attest to this
But its not often the case, really.
how are you controlling boost? It may very well be that the boost controller you are using is causing the spike and/or your wastegate vacuum lines.
Old Feb 9, 2004 | 01:17 PM
kpt4321's Avatar
A/F ratio and timing can effect creep, but not spike.
Mase, what the hell are you talking about, creep? He specifally said in his post that it will hold 8 psi "rock steady." That means it's not creeping.
Old Feb 9, 2004 | 01:27 PM
Mase's Avatar
Default Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">A/F ratio and timing can effect creep, but not spike.
opps, good call, i totally read that wrong.
my bad.
yes this is a spike, not a creep.
Creep is caused by too much exhaust energy going thru the turbo instead of the wastegate. If the wastegate spring is too stiff the valve will sometimes not open all the way, which can cause creep.
like i said before it could be the boost controller..
Old Feb 9, 2004 | 01:30 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
especially when in your sig, you are trying to represent full-race</TD></TR></TABLE>
there crybaby i took full-race out of my sig, just for you.
btw, i havent made fun of anyone.
Old Feb 9, 2004 | 01:31 PM
dfoxengr's Avatar
please dont get mad at me when you made the mistake.
Old Feb 9, 2004 | 01:33 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">please dont get mad at me when you made the mistake.</TD></TR></TABLE>
the only mistake ive made today is calling this creep instead of spike.
the question on the topic title was can air fuel ratio affect boost pressure. chances are no, ignition timing can, but not near as much as manifolds can.
Old Feb 9, 2004 | 03:30 PM
aka010010
Guest
Posts: n/a
stop fighting already.
u guys havent seen mase get madd yet. lol...i have...many times.
Old Feb 9, 2004 | 03:42 PM
Mase's Avatar
Default Re: (aka010010)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aka010010 &raquo;</TD></TR><TR><TD CLASS="quote">stop fighting already.
heh, when have you seen me get mad? i havent lost my temper in a very long time
Old Feb 9, 2004 | 03:56 PM
Default Re: (Mase)
2 words. anger management...
jus playin
94turboeg
Aug 13, 2007 12:08 AM
RTW DC2R
Nov 17, 2006 03:19 PM
SleepinTeg
Sep 27, 2005 01:37 PM
Sketch_hs
Aug 10, 2004 09:06 PM
