-----WB O2 Voltage----- Use a graphing calculator to log AFR?
Old Feb 9, 2004 | 10:20 AM
Bailhatch's Avatar
Default -----WB O2 Voltage----- Use a graphing calculator to log AFR?
So my DIY WBO2 project is coming together. I will basically have a box that puts out 0-5v signal. Could I use a Ti-88 or similar graphing calculator to log the voltage signal and graph it? I did this in school but can't remember if there are any limitations to this method.
Is the accuracy of these calculators good enough to get me within a 1/4pt on the AFR scale? Is there a way you could program the calc to convert the input to reflect true AFR not just V?
Old Feb 9, 2004 | 04:58 PM
Bailhatch's Avatar
Default Re: -----WB O2 Voltage----- Use a graphing calculator to log AFR? (Bailhatch)
you can't tell me there are no calculator experts on here
Old Feb 9, 2004 | 05:00 PM
DaX's Avatar
DaX
Loved
Community Favorite
Only thing I would be concerned with is the sampling rate, and the very limited memory of TI Graphing Calculators.
Old Feb 10, 2004 | 08:03 AM
loSthoPe's Avatar
Default Re: (DaX)
go on
Old Feb 10, 2004 | 02:25 PM
Bailhatch's Avatar
Default Re: (loSthoPe)
HAHAHAHA
Old Feb 10, 2004 | 03:00 PM
boosted92's Avatar
Default Re: (Bailhatch)
Sampling rate isn't high enough, and not enough memory in em. If you want something like that, run a palm.
Old Feb 10, 2004 | 03:34 PM
Bailhatch's Avatar
Default Re: (boosted92)
I have a plam but where could I get a program to log and/or convert voltage? I am building the diywb so i'm not sure if there are any palm programs for it.
Old Feb 10, 2004 | 07:57 PM
totalimpact's Avatar
OOOH you will love this:
http://www.ecucontrol.com/ - badars datalogging ware for PDA.
http://www.pgmfi.org/phorum/ - that site is everything you need for ecu programming.
good luck
Old Feb 10, 2004 | 08:19 PM
stierhund's Avatar
anytime you want to log information like that you have to have an analog to digital converter... a TI calculator works entirely off of digital signals in its inputs
same with a pocket pc, I am sure that someone has a setup that was made to take voltage inputs from pressure transducers, thermocouples, oxygen sensors, etc
Old Feb 10, 2004 | 08:44 PM
Bailhatch's Avatar
Default Re: -----WB O2 Voltage----- Use a graphing calculator to log AFR? (stierhund)
is analog to digital needed for displaying the voltage too? I assume not because you can use a mutimeter to display the output v of the WB controller. So if i want to use a plam pilot, I would need another 'box' to convert the WB controler output to a digital signal, as well as run some special program for the palm? I'm not really into electronics so please keep it dumb for me
Old Feb 10, 2004 | 09:12 PM
Bailhatch's Avatar
pgmfi.org, makes my head swim. info overload
Old Feb 10, 2004 | 09:14 PM
Joseph Davis's Avatar
Digital means the power is either on or off. Analog means the power level varies, like your WBO2's output.
You might consider ditching the older DIY-WB board and grab a Techedge 1.5 at a fair price... there is Palm logger software available for OS 3.5+, you just need the serial data cable for the Palm and a null modem connector. Logs AFR and RPM.
Old Feb 11, 2004 | 05:25 AM
loSthoPe's Avatar
Default Re: -----WB O2 Voltage----- Use a graphing calculator to log AFR? (J. Davis)
go on...heres a snackerl http://www.pocketlogger.com/ i didnt read it much but there seems to be some info
Old Feb 11, 2004 | 06:10 AM
Default Re: -----WB O2 Voltage----- Use a graphing calculator to log AFR? (loSthoPe)
Pocketlogger looks good for obdII.
http://wbo2.com/ Thats something you may want to check out, its some sort of DIY project for cheap WB, they have a digital display.
http://www.nitroburn.com/pgmfiwiki/ - thats the most useful thing on pgmfi, its slightly more organized than the main forums, and the info is more to the point. There is a wideband section in there as well. i could read pgmfi forums for days and still be lost in space
Old Feb 11, 2004 | 06:26 AM
dennis's Avatar
Interesting info - I remember reading somewhere about someone doing some cool stuff with the graphing calcs.
My upcoming project (after I finish my helmet cam - man I have too many projects...) is going to be using a Labjack U12 (http://labjack.com/labjack_u12.html) for all my data acquisition and logging.
Might be a viable option for others too. I have a friend that's currently using it on his Z for the same thing.
Like the others mentioned - you'll get much more love (or just be flamed worse) at pgmfi.org - good luck
Old Feb 11, 2004 | 06:53 AM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Digital means the power is either on or off. Analog means the power level varies, like your WBO2's output.
You might consider ditching the older DIY-WB board and grab a Techedge 1.5 at a fair price... there is Palm logger software available for OS 3.5+, you just need the serial data cable for the Palm and a null modem connector. Logs AFR and RPM.</TD></TR></TABLE>
like 1s and 0s vs. waves right?
I see what your saying about the TE 1.5 it is exactly what I want but it really isn't in the budget (300ish used). I will be able to do the DIY wb for about 120 including the project box and other misc parts. down the road a more versitial WB will definatly be in my car but for now...
I guess what i'm looking for then is an easy way to just display my WBO2 voltage. I don't nesscaraily need to convert it to AFR to have it be usefull. I was planing on zip tieing my multi meter next to my safc (displaying correction & rpm) and just filming it as I make pulls
could I just get a digital volt gauge and use that? I would be stoked to have a small display that just showed my O2 voltage, just for safety...."oh no it's below 2.2v" or whatever. stupid idea?
pocketlogger is a no go for OBD1 hondas
wbo2.com is the techedge J davis is talking about.
Old Feb 11, 2004 | 08:12 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">like 1s and 0s vs. waves right? </TD></TR></TABLE>
Correct. Digital sees highs and lows and analog see's what looks like an oscilloscope [sine wave].
Old Feb 11, 2004 | 02:47 PM
Bailhatch's Avatar
Default Re: -----WB O2 Voltage----- Use a graphing calculator to log AFR? (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
Correct. Digital sees highs and lows and analog see's what looks like an oscilloscope [sine wave].</TD></TR></TABLE>\
sweet, well that sums up my knowledge of electronics.
so anyone have some ideas how I can make a ghetto (read - VERY inexpensive) voltage or AFR display. since I apparently built the wrong WB controller
i guess the big yellow multi tester has a new home in my hatch...
98vtec
Jan 17, 2008 04:00 PM
vladd
Jun 19, 2006 05:43 AM
mdixonjam
Jul 13, 2005 09:53 PM
hybrid_vtec
52
Dec 27, 2004 10:20 AM
civic disobedience
Sep 18, 2002 07:33 AM
