do i need another o2 bung for wideband, or do i use the original one?
Old Jun 18, 2006 | 01:09 PM
vladd's Avatar
Default do i need another o2 bung for wideband, or do i use the original one?
When I go to tune my turbo gsr, the tuner is going to have a wideband o2 that he's going to use on my car. Do I leave the stock o2 in, and get a 2nd bung for the wideband o2, or do I pull the original one out and put the wideband in there? I need to know asap because I'm ordering a straight pipe and need to know how many o2 bungs I need.
Old Jun 18, 2006 | 01:16 PM
adseguy's Avatar
Default Re: do i need another o2 bung for wideband, or do i use the original one? (civicdxtyper)
The original one is fine for a spot, but make SURE that the stock one can come out easily. 3 times I've had to cancel tuning because the owners didn't check to make sure the 02 sensor easily comes out. If it's old and rusted shut you may have to use a torch to heat up the bung and use PB blaster as well.
Old Jun 18, 2006 | 03:34 PM
vladd's Avatar
Default Re: do i need another o2 bung for wideband, or do i use the original one? (adseguy)
ok, i'll loosen it before taking it down for tuning. but you're 100% sure i won't need both in at the same time, right?
Old Jun 18, 2006 | 04:13 PM
adseguy's Avatar
Nope. If your tuner decides to use closed loop after the tune then you'll need it plugged in afterwards, but otherwise you don't need it at all if you tuner is good
Old Jun 18, 2006 | 04:38 PM
Mr.Death's Avatar
Just add a new bung and plug it when not in use.
Old Jun 18, 2006 | 05:15 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Nope. If your tuner decides to use closed loop after the tune then you'll need it plugged in afterwards, but otherwise you don't need it at all if you tuner is good </TD></TR></TABLE>
we set most of ours up after tune in open loop. but as stated, if your tuner uses closed loop, you do need 2 bungs. we put a second one in anyway, so it is there.
Old Jun 19, 2006 | 05:43 AM
vladd's Avatar
the o2 won't be in there permanently; only for the tune, but i guess i'll get 2 bungs just in case.
Nextelbuddy
May 25, 2004 09:34 AM
3gLudeH22A
Dec 13, 2002 02:45 PM
civic disobedience
Sep 18, 2002 07:33 AM
