fuel pump problems?
Old Feb 7, 2004 | 10:07 PM
shoebox's Avatar
Default fuel pump problems?
I think that my fuel pump is going out but before i pull down my fuel tank, I want to make sure that there is not anything obvious that I am missing. I pulled the fuel line off of the fuel rail and turn the key on, No fuel came out. That is the only real test I know of. I can't hear the pump kick on when I turn the key on, but is there a main fuse at all that can be blown? If anyone knows let me know. Thanks guys!
Old Feb 7, 2004 | 11:21 PM
Redline130's Avatar
Default Re: fuel pump problems? (shoebox)
Check your main relay to see if it's working. Mostly likely it's not if your fuel pump isn't priming when you turn the key to the on position.
Old Feb 8, 2004 | 06:41 AM
shoebox's Avatar
Default Re: fuel pump problems? (Redline130)
Where is the main relay?
Old Feb 8, 2004 | 09:35 AM
blah13's Avatar
If the main relay is gone the pump wont start. When you turn your key to II and the cel comes on, you should hear a click near your left foot, then when the cel turns off another click. This is the main relay sending power to the pump to prime the system. Its like $35 for the relay but it can be a pain to get to. Its behind the panel closest to the door, get upside down and look up in there and youll see it.
Old Feb 8, 2004 | 01:04 PM
shoebox's Avatar
Default Re: fuel pump problems? (blah13)
I just checked if I had spark, and I didn't. Is that part of the main relay too?
Old Feb 8, 2004 | 01:59 PM
didyouhearthat's Avatar
I just had that fixed. Main fuel relay, is it? Had it taken out and found out it was "burnt out". Sodered the heads in the back of chip and it was good to go. Before, my car would start once and a while, but not 100%.
... . . . hasTA
Old Feb 11, 2004 | 11:18 AM
esoterEK..'s Avatar
Default Re: fuel pump problems? (didyouhearthat)
ignition module?
Dxvid
May 2, 2019 02:05 PM
EJ8CIVIC
Jul 7, 2015 03:47 AM
BlueIntegraBoy
18
May 10, 2006 09:31 PM
iwhichisme
Sep 8, 2004 04:13 AM
