Clunky Idle. Need Help
Old Feb 7, 2004 | 03:14 AM
slowd16z6's Avatar
Default Clunky Idle. Need Help
Just installed new header. I was having somewhat of a odd idle prior to the install, but now it is extremely bad. My rpms range from 900 all the down to 400 and the engine feels like it wants to die. Also in idle I hear an odd popping noise through the whole exhaust system. Does anyone know what the problem might be and how to fix it?
Old Feb 7, 2004 | 03:04 PM
slowd16z6's Avatar
Default Re: Clunky Idle. Need Help (slowd16z6)
bump
Old Feb 7, 2004 | 03:23 PM
TurboBumblBee's Avatar
did you reset the ecu after putting the new aftermarket header in???
Old Feb 8, 2004 | 02:42 PM
slowd16z6's Avatar
Default Re: Clunky Idle. Need Help (b18c1hybridhatch)
I turned the car off and detached the pos cable from the batt. for about 10 mins then let it sit idle for 10 mins w/ out pressing the gas. Idle jumps up and down and also a poping noise going through the whole system. I also removed the heat shield and I still hear it rattleing all over any ideas how to fix these problems?
Old Feb 9, 2004 | 02:26 PM
slowd16z6's Avatar
bump
Old Feb 9, 2004 | 02:32 PM
92civeg's Avatar
did you hook your o2 sensor back up?
Old Feb 11, 2004 | 08:11 AM
slowd16z6's Avatar
Default Re: Clunky Idle. Need Help (92civeg)
yes
Old Mar 10, 2004 | 11:09 PM
slowd16z6's Avatar
bump
Old Mar 11, 2004 | 01:06 AM
Formula 1's Avatar
try adjusting your timing
try the idle adjustment screw on the TB
sounds like timing is off cuz of the poping
hans0222
Honda Civic (2001 - 2005)
Jul 27, 2018 05:00 PM
0ldsk00lef
Sep 9, 2007 08:50 AM
ex94vtec
14
May 6, 2006 02:07 AM
Gump
12
Dec 5, 2003 02:11 PM
Btothe3rdDegree
Jun 26, 2003 09:08 PM
