CTR Intake CAM in GSR HEAD
Old Feb 4, 2004 | 11:40 PM
lo0nY's Avatar
Default CTR Intake CAM in GSR HEAD
just picked up a CTR INTAKE CAM, and was wondering if I would see and feel a diference , if i keep the stock GSR exhaust cam, and install the CTR intake cam would that be safe and ok?
Old Feb 4, 2004 | 11:43 PM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
Default Re: CTR Intake CAM in GSR HEAD (lo0nY)
not to be a dick, but how would u "see" a difference?
Old Feb 4, 2004 | 11:46 PM
kool168's Avatar
you will feel the different, but not that BIG different...
Old Feb 4, 2004 | 11:56 PM
lo0nY's Avatar
Default Re: CTR Intake CAM in GSR HEAD (SOL-R)
see the difference, with someone driving my car down the track...and break 13's
Old Feb 5, 2004 | 03:00 AM
pdiggitydogg's Avatar
break 13's?
no
Old Feb 5, 2004 | 05:00 AM
SOHC_MShue's Avatar
break 13's?
What car is this motor in?
Old Feb 5, 2004 | 09:52 AM
kool168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY &raquo;</TD></TR><TR><TD CLASS="quote">see the difference, with someone driving my car down the track...and break 13's</TD></TR></TABLE>
you must be kidding man
Old Feb 5, 2004 | 10:43 AM
Kidnkorner's Avatar
your gsr intake cam is designed to be used with your dual runner intake manifold. replacing the intake cam with a civic type r cam will cause you to lose some of that low and mid range power you have now.
_____________
im a jackass don't listen to me
For the finest in JDM engines and better pricing than hmotorsonline.com Click Here
[B][I] Can you hear me now? Good!!
2000 EK HB
Modified by Huggy Bear at 4:20 PM 2/5/2004
Old Feb 5, 2004 | 10:54 AM
slixxracing's Avatar
Default Re: CTR Intake CAM in GSR HEAD (Huggy Bear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear &raquo;</TD></TR><TR><TD CLASS="quote">your gsr intake cam is designed to be used with your dual runner intake manifold. replacing the intake cam with a civic type r cam will cause you to lose some of that low and mid range power you have now.</TD></TR></TABLE>
what if you upgraded it to a skunk2 manifold...would it make a difference then?
Old Feb 5, 2004 | 10:55 AM
Matty.'s Avatar
do it and let us know. if you lost power then get a skunk manifold and chip that POS ECU.
Old Feb 5, 2004 | 11:46 AM
Kidnkorner's Avatar
Default Re: CTR Intake CAM in GSR HEAD (slixxracing)
i almost suggested this<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slixxracing &raquo;</TD></TR><TR><TD CLASS="quote">
what if you upgraded it to a skunk2 manifold...would it make a difference then?</TD></TR></TABLE>
_____________
2000 EK HB
Modified by Huggy Bear at 4:21 PM 2/5/2004
Old Feb 5, 2004 | 12:44 PM
rodrez.'s Avatar
If you drop the CTR intake cam in your car, you will notice a difference. The exhaust cam is not much bigger than the stock one, so you won't see much difference with it, compared to just the intake cam upgrade.
I highly recommend the Skunk2 intake manifold, as it will aid it making more top end power, especially with the new intake cam.
As far as hitting 13's, this is possible depending on what car it's going into, and if you can drive/have traction (decent slicks).
boostsohfast's Avatar
I've seen a type-r intake cam with the skunk2 IM and gsr exhaust cam on a b18c1 and it did make a difference.... but not much.
Old Feb 5, 2004 | 12:51 PM
Spirit Iron knife's Avatar
Default Re: CTR Intake CAM in GSR HEAD (boostsohfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">I've seen a type-r intake cam with the skunk2 IM and gsr exhaust cam on a b18c1 and it did make a difference.... but not much. </TD></TR></TABLE>
Was it tuned on the dyno with an experienced tuner? Because adding a Type R exhaust cam on that set up is not going to do anymore. Might allow a bit more adjustment on the exhaust cam to allow for a powerband tailoring, but not much more. The ITR/CTR exhaust cam is not worth the money, unless you're getting a good package deal.
Old Feb 5, 2004 | 01:34 PM
fred92htch's Avatar
I put in both CTR cams and a Skunk2 intake and felt a very noticable difference. Espacially on the top end.
Old Feb 5, 2004 | 02:56 PM
Default Re: CTR Intake CAM in GSR HEAD (fred92htch)
so you guys think ctr cams would make a difference if it's in a turbo application car? I know you probably wont be able to feel the difference but maybe the dyno can see the difference.
Old Feb 5, 2004 | 04:06 PM
Default Re: CTR Intake CAM in GSR HEAD (Cult of Staxx)
I admit the car was never tuned and it probably had more potential... The car was not mine, it was a friends. We knew about the exhaust cam so thats why we didn't get it. My car pulled on him just about the same as before when he upgraded to the type-r cam. I will say it felt better on the top end.
Old Feb 5, 2004 | 04:40 PM
rodrez.'s Avatar
If anyone in this thread is interested, I just pulled the Skunk2 intake manifold off my old blown GSR, am looking to sell it. It's in perfect condition, about to put it in the classifieds as soon as I take a couple of pics this weekend. Just a heads up
Old Feb 5, 2004 | 04:46 PM
Matty.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slixxracing &raquo;</TD></TR><TR><TD CLASS="quote">so you guys think ctr cams would make a difference if it's in a turbo application car? I know you probably wont be able to feel the difference but maybe the dyno can see the difference. </TD></TR></TABLE>
NA cams = no good for turbo
gsr cams are fine
Old Feb 5, 2004 | 04:52 PM
Patrick's Avatar
I had 2000 ITR cams (same as CTR) in my Civic with a Skunk2 ITM and the top pulled so nice, straight through 3rd and 4th.
Old Feb 8, 2004 | 07:18 PM
lo0nY's Avatar
is anyone selling Type R exhaust cams?? let me know thanks
danny98r
Apr 8, 2004 08:14 AM
92 civic VX B18c
Sep 15, 2003 06:16 AM
Weslay
Mar 4, 2002 10:16 AM
