Throttle Cable on a GSR Swap
Old Feb 3, 2004 | 06:17 AM
mrbsponge's Avatar
Default Throttle Cable on a GSR Swap
I just pulled out my LS motor in favor of a gsr on my 95 hb. I was told to use the throttle cable from my LS but it's about 5" too long. WHat throttle cable should I be using? Thanks.
Old Feb 3, 2004 | 06:21 AM
stockegsix's Avatar
Default Re: Throttle Cable on a GSR Swap (mrbsponge)
get the gsr cable.
i have a 92 hatch w/ a b18c1
Old Feb 3, 2004 | 06:23 AM
toolowsol's Avatar
Default Re: Throttle Cable on a GSR Swap (stockegsix)
make it work, if its too long, just loop it back a little.... Mine worked fine, just gotta make it work.
Old Feb 3, 2004 | 07:08 AM
degooser's Avatar
yah i used my stock d16 throttle cable and it worked fine..
Old Feb 3, 2004 | 07:16 AM
monicle's Avatar
easy way to fix it.
Old Feb 3, 2004 | 07:23 AM
HXMan's Avatar
Default Re: Throttle Cable on a GSR Swap (monicle)
I did something similar to that. I had an extra rubber isolator so I cut it in half, only have way thru along the length of the isolator. I then slipped it over the throttle cable, and a zip tie on each end holds keeps it from popping off the cable when the throttle is applied.
Old Feb 3, 2004 | 08:52 AM
93CivicSiSOHC's Avatar
i have a LS swap in my hatch and i used a Del Sol VTEC throttle cable and it worked great...better to spend the $14 instead of rigging it.
Old Feb 3, 2004 | 09:12 AM
ueatdooki's Avatar
Default Re: (93CivicSiSOHC)
I used my stock line, just loop around your engine bay until it feels tight
Old Feb 3, 2004 | 09:31 AM
dwnthehatch's Avatar
Default Re: (ueatdooki)
You can use either the stock civic cable or the gsr cable. I have used both.
Old Feb 3, 2004 | 10:21 AM
dunkd's Avatar
i used stock throttle cable on my gsr swap in a eg... nothing zipties cant fix
Old Feb 3, 2004 | 03:52 PM
mrbsponge's Avatar
Thanks guys, i went for the gsr cable. It fits perfect.
Old Feb 3, 2004 | 04:03 PM
dantastic's Avatar
just fyi: you can use a stock 92-95 d series throttle cable for the gsr motor. LS, b16a/b, and b18c-r motors use can use the same throttle cable.
g0tgot
Oct 11, 2008 07:50 AM
ateggy1
Mar 17, 2008 09:27 PM
123Four
Sep 12, 2007 03:08 PM
lsvtecboi'95
Aug 4, 2007 07:53 PM
zm_dawg
Jul 12, 2004 09:53 AM
