B20b smoking but compression and leakdown look great. Any help?
Old Feb 3, 2004 | 05:46 AM
Will Albers's Avatar
Default B20b smoking but compression and leakdown look great. Any help?
Well here are the numbers:
1: 2%
2: 3.5%
3: 3.5%
4: 2%
Compression
evens have 171
odds have 168
This was all using a digital set of gauges on a b20b that was turboed. It smokes pretty bad while shifting and at idle. i had thought it was the turbo, but i removed it and it still smokes. What else could it be? bad PCV system? too much fuel? What can i check?
The smoke is dark in color and smells like burning oil.
Old Feb 3, 2004 | 11:48 AM
Default Re: B20b smoking but compression and leakdown look great. Any help? (Will Albers)
just moves to fast to the back
Old Feb 3, 2004 | 12:12 PM
Dan GSR's Avatar
valve seals
good idea to check out the pcv as well
Old Feb 3, 2004 | 03:28 PM
LudeyKrus's Avatar
Maybe you're running rich? Valve seals are also a possibility...
Old Feb 3, 2004 | 04:27 PM
Sliced Beard's Avatar
Default Re: (LudeyKrus)
i would definately reccomend replacing valve seals
Old Feb 5, 2004 | 10:56 PM
civicsitek GanGsTa's Avatar
Default Re: (dirtyd463)
How many miles are on the engine?
Old Feb 6, 2004 | 07:45 AM
haggar's Avatar
Default Re: (civicsitek GanGsTa)
I also think maybe valve seals...
Have you pulled the spark plugs? Or the header/exhaust minifold?
On a non-honda motor(An AMC 304 cu. i. V8, to be exact) that I had in my Jeep, I had the valve seals go out, same thing, good comp & leakdown. 5 cylinders had pretty bad valve seals, was easy to see by the oil-foiled plugs and oily residue in those exhaust runners...
Old Feb 6, 2004 | 04:15 PM
virginia_dude's Avatar
Oil rings sticking, broke or worn have no effect on compression and leakdown test. But there are other possibilities, valve stem seals are another, even clogged pcv valve.
Redprelude98
30
Jul 21, 2009 01:21 PM
th3pwn3r
Aug 5, 2008 06:32 PM
civtic
Mar 6, 2008 10:22 PM
lke2drvgsr
Apr 14, 2004 10:01 AM
RTW DC2R
Mar 19, 2004 09:05 AM
