ls vs ls vtec
Old Feb 2, 2004 | 06:57 PM
redteg's Avatar
Default ls vs ls vtec
i am running the following setup on my ls ported and polished head, cams, valvetrain,header, manifold, tb. and my compression is just around 11.1. can i squeeze some more out of this setup or just build an ls vtec i would use a b16 head ported with ctr intake cam and itr exhaust cam skunk2 manifold for the top end. The bottom end i would use a b18b1 block with itr pistonson shot peened ls rods all balanced and i would use arp rod bolts on them. Now the question is how much of a difference would i see from my non vtec ls setup i just posted. if their is only a 20 horse difference then it would be a waste to do but i don't know so i wanted to get some feedbak on it. also please post your setup just for future help and knowledge thanks alot.
Old Feb 3, 2004 | 01:06 PM
Flexmyrex's Avatar
Default Re: ls vs ls vtec (redteg)
the vtec head you listed is deff going to help make pwr, no question about it. go with ctr pistons to bump the cr
its all you keep us posted
Old Feb 3, 2004 | 01:19 PM
JerseySiPOS's Avatar
in a builder's aspect, i dont even understand why some people even bother with a b20 or ls head.
thats like the new fad or something these days. not flaming you or anything. JMO
go with the vtec head. the stock head even with out pnp flows great.
E Lo
Old Feb 3, 2004 | 06:23 PM
redteg's Avatar
Default Re: ls vs ls vtec (JerseySiPOS)
thanks for the info but what pistonsshould i run will i make enough power using itr pistons
Old Feb 3, 2004 | 07:25 PM
krazie1's Avatar
BANNED
i would stick with ITR
cuz as soon as u use CTR u going to have to either run 100 and above fuel
which ain't easy to afford around here and find
or run at a retarded time and suck *** on the streets
so i would stick with ITR
but that is my opinion
u can do what u like, bro
Old Feb 4, 2004 | 06:12 AM
Spoonin's Avatar
Default Re: ls vs ls vtec (krazie1)
For people that think you need to have some crazy *** parts and high *** compression to make good power just look at the dyno on this page http://www.importreview.com/d_1.8.html
The one near the bottom titled "1994 B18B - Atomic's Car" pretty impressive.
Old Feb 4, 2004 | 06:17 AM
ekaaron's Avatar
Default Re: ls vs ls vtec (Spoonin)
ls/vtec all the way
Old Feb 4, 2004 | 07:47 AM
notsure's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonin &raquo;</TD></TR><TR><TD CLASS="quote">For people that think you need to have some crazy *** parts and high *** compression to make good power just look at the dyno on this page http://www.importreview.com/d_1.8.html
The one near the bottom titled "1994 B18B - Atomic's Car" pretty impressive.</TD></TR></TABLE>
how the hell is that possible, 204 on all stock parts. thats insane. i am hoping to break 200 and i am no where near stock.
Old Feb 4, 2004 | 01:10 PM
95 10 SEC LS VTEC's Avatar
TRUST ME YOU DO NOT WANT TO USE ANY OEM PISTON IF YOU WANT GOOD CONSISTANT COMPRESSION I WENT THE WAY YOU KIND OF ARE GOING AND IT WAS HORRIBLE I RUN 13TO1 WIESICO'S NOW WITH STOCK ROD STOCK CRANK I HAVE 1.7 GSR HEAD OLD SCHOOL BUT THE BEST COMBO I THINK. I'VE RAN FULLY PORTED 1.8GSR B16 B20 BUT THIS COMBO OUT PREFORMS ALL JUST THINK ABOUT 11TO1 OR 13TO1 FOR MAYBE 100 BUCKS MOR AND MORE LIABILITY THEY ARE BUILT FOR IT CTR OT ITR ARE NOT. HOPE THIS HELPS YOU OUT
Old Feb 5, 2004 | 03:38 AM
Spoonin's Avatar
Default Re: ls vs ls vtec (95 10 SEC LS VTEC)
95 10 SEC LS VTEC,
WHEN I READ THAT LAST POST, I GOT A HEADACHE AND PASSED OUT THEN GOT UP AND WROTE THIS POST. Then I fixed the caps lock key.
notsure,
I think that guy had Toda spec A cams. They were kinda shady on what else he had.
Old Feb 5, 2004 | 06:42 AM
11sec CR-X's Avatar
My best friend runs CTR pistons in his LS/VTEC and he runs on 93 octane. No ping at all smooth as glass.
Old Feb 5, 2004 | 06:44 AM
11sec CR-X's Avatar
Default Re: ls vs ls vtec (11sec CR-X)
I run B20 VTEC on 12.5:1 compression on 93 octane in my B20 on stock sleeves too. I think LS/Vtec with CTR pistons yields a 12.1 compression ratio on LS/Vtec but not exactly sure..... Both his and my motors run great...
Old Feb 5, 2004 | 01:55 PM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 10 SEC LS VTEC &raquo;</TD></TR><TR><TD CLASS="quote">TRUST ME YOU DO NOT WANT TO USE ANY OEM PISTON IF YOU WANT GOOD CONSISTANT COMPRESSION I WENT THE WAY YOU KIND OF ARE GOING AND IT WAS HORRIBLE I RUN 13TO1 WIESICO'S NOW WITH STOCK ROD STOCK CRANK I HAVE 1.7 GSR HEAD OLD SCHOOL BUT THE BEST COMBO I THINK. I'VE RAN FULLY PORTED 1.8GSR B16 B20 BUT THIS COMBO OUT PREFORMS ALL JUST THINK ABOUT 11TO1 OR 13TO1 FOR MAYBE 100 BUCKS MOR AND MORE LIABILITY THEY ARE BUILT FOR IT CTR OT ITR ARE NOT. HOPE THIS HELPS YOU OUT</TD></TR></TABLE>
People talk..
Old Feb 5, 2004 | 03:01 PM
C8V6C's Avatar
What about 91 oct gas?
I wanted .25 over with ctrsin an 1.8 ls and skunk 2 stage 2 cams in B16A head, but I figured the timing would have to be retarted, and then ran on 100.
And how would make sure that you burn all the gas of 91 octane, and then be runnin on the 100 when u wanna race? Just buy like 5 gallons of race gas, lol?
hatchmonkey92
May 5, 2005 09:25 AM
Forrest Gump 9
Sep 9, 2003 07:35 PM
KW2000
Mar 6, 2003 09:02 AM
92HB_HB
Jun 26, 2002 09:11 PM
