F-max, Drag, Greddy???
Old Feb 2, 2004 | 05:36 PM
Memo6453's Avatar
Default F-max, Drag, Greddy???
OK, well everybody wants a turbo kit, but doesnt wanna build the motor. I am that person. OK well f-max comes with that msd ignition thing(btm), and drag doesnt. Greddy doesnt come with a front mount interco0ler, and doesnt have an external wastegate, but happens to be the cheapest, regardless of the i/c. I just want to run high 13's at a decent pressure of like 6-7 or even 8 psi...it will be dyno'ed and installed correctly
Drag - $2950
F-max- $3100
Greddy (no I/C) - $2600
which one should i get that would be the safest on the motor, and still have go0d dyno #'s? Any one with dyno's of any of these kits please post, i believe they are all under 250whp...any suggestions???
Old Feb 2, 2004 | 05:49 PM
SMOOTH97LUDE's Avatar
Default Re: F-max, Drag, Greddy??? (Memo6453)
all turbo kits are safe. at least those that are tuned by a pro. The greddy kit is a nice kit, but have you priced a greddy intercooler?
Old Feb 2, 2004 | 05:58 PM
satan_srv's Avatar
Default Re: F-max, Drag, Greddy??? (SMOOTH97LUDE)
Isn't custom the best way to go? Then you don't get stuck with crappy electronic and fuel management
Old Feb 2, 2004 | 06:53 PM
specalk's Avatar
Default Re: F-max, Drag, Greddy??? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">Isn't custom the best way to go? Then you don't get stuck with crappy electronic and fuel management</TD></TR></TABLE>
yes it would be, theres a shop in orlando that will do a complete setup for $right under 3k with IC and fuel management and injectors and dyno tune on there own dyno. I was looking into it about 2 years ageo and decided against it.. but its the better way to go. one thing i do like is the manafold on the greddy
Old Feb 3, 2004 | 01:09 PM
Memo6453's Avatar
Default Re: F-max, Drag, Greddy??? (specalk)
whats the name of the place???
And wheres a store online with go0d prices that you have heard go0d about?
Old Feb 3, 2004 | 03:25 PM
NOTENOUGHBOOST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Memo6453 &raquo;</TD></TR><TR><TD CLASS="quote">whats the name of the place???
And wheres a store online with go0d prices that you have heard go0d about?</TD></TR></TABLE>
http://www.hondadriven.net
Old Feb 3, 2004 | 03:31 PM
Mykizism's Avatar
you can get the greddy turbo kit and fmic for 2999.99 from these people i know that sell their kit on ebay.
from experience the greddy kit is hands down the best one for the lude
fmax drag
Modified by Mykizism at 7:10 PM 2/3/2004
Modified by Mykizism at 7:11 PM 2/3/2004
Old Feb 3, 2004 | 08:28 PM
supaZZZleepa's Avatar
Default Re: F-max, Drag, Greddy??? (Mykizism)
custom is the way to go. i don't like the greddy...i've seen some disappointing numbers put up by turbo'd built ludes with the greddy.
Old Feb 3, 2004 | 08:57 PM
CloudDragon's Avatar
I'd prob go with the Revhard kit or the Drag kit. Tuning is the key.
Old Feb 4, 2004 | 08:56 AM
ViZ's Avatar
ViZ
Default Re: (CloudDragon)
the drag kit has piping fitment issues.. they can and eventually fit but they like to give you a hard time
Old Feb 4, 2004 | 09:22 AM
graphic's Avatar
Default Re: (ViZ)
f-max works for mE yO!
Old Feb 4, 2004 | 09:28 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">from experience the greddy kit is hands down the best one for the lude</TD></TR></TABLE>
Yep... it's hands down the best one for the least amount of power to produce.
Old Feb 4, 2004 | 10:11 AM
musclefella's Avatar
Default Re: F-max, Drag, Greddy??? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Yep... it's hands down the best one for the least amount of power to produce.</TD></TR></TABLE>
LOL good one.
Try and make a custom turbo setup, you'll be more satisfied in the end (maybe)
It's your own creation, if it works then that's a good enough reward, plus nobody's got what you've got.
Old Feb 4, 2004 | 12:48 PM
Mykizism's Avatar
Well of course it will make the least amount of power between the choices.
The Greddy kit was designed on stock motor.. stock car. Its a pure bolt on turbo kit that requires no fabrication, no drilling nothing.. Its pure bolt on for a pretty much stock car. That will make good "safe" amount of power.
You can ditch the Greddy FCU and go with a Stand alone system then make more power from there. but there are only limitations to how much power you can make before the ring lands go.
Old Feb 4, 2004 | 01:51 PM
GruvyTune's Avatar
New User
i reviewed the drag gen 4 kit a while back along with pics and dyno charts
on my built motor, got 387HP at the wheels at 15psi. needed only minimal cutting to mount the kit and the overall finish is nice.
Old Feb 4, 2004 | 01:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">The Greddy kit was designed on stock motor.. stock car. Its a pure bolt on turbo kit that requires no fabrication, no drilling nothing.. Its pure bolt on for a pretty much stock car. That will make good "safe" amount of power.
You can ditch the Greddy FCU and go with a Stand alone system then make more power from there. but there are only limitations to how much power you can make before the ring lands go.</TD></TR></TABLE>
All 'kits' are pretty much designed on a stock motor. Boohoo you have to cut the front bumper support to fit the intercooler. Boohoo you have to do a MINOR amount of fabrication here and there. On B series you have to notch out a part of the webbing near the transmission side of the block. If you can't do these simple things you don't deserve to own a turbocharged vehicle. For the amount of money spent I would rather have a kit that produces power and spend an extra hour on the install. But then again... you would think every company would design a simple 'bolt-on no modification necessary' type of turbo kit. If you have designed a kit you would realize it's more work then you think to have everything fit properly.
Just like any other kit, you can always upgrade to a standalone and get more power.
Old Feb 4, 2004 | 03:10 PM
H22A EG6's Avatar
i need a turbo!
Old Feb 4, 2004 | 08:30 PM
2001teggsr's Avatar
F-max= crap small trim t3/t4 crappy piping; Greddy=internal wastegate, crap; Drag is the way to go just dont use the fuel pressure riser and helper pump its crap also get bigger injectors and someway to control them....Rev Hard int bad either....good luck with your decision
Old Feb 5, 2004 | 09:52 AM
machinehead's Avatar
im thinking about piecing together a cheap kit. aiming for 300whp with 6 or 7 psi, nothing major. gotta keep it safe for the stock block.
Old Feb 5, 2004 | 02:39 PM
2001teggsr's Avatar
Default Re: (machinehead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machinehead &raquo;</TD></TR><TR><TD CLASS="quote">im thinking about piecing together a cheap kit. aiming for 300whp with 6 or 7 psi, nothing major. gotta keep it safe for the stock block.</TD></TR></TABLE>OK not to make you mad dude but dont go the cheap way out and 300 whp will not be made on 6 or 7 psi thats just a mathmatical certainty especially on the stock block......
Old Feb 5, 2004 | 09:38 PM
killa_lude's Avatar
Default Re: (2001teggsr)
fmax sucks, greedy well i havent seen good numbers on a greddy kit, compared w/ a revhard! Go revhard, and get hondata or a ems and your set for 7psi...
mvp97gsr
Jun 14, 2006 05:01 AM
Marteinn
Jul 26, 2005 10:32 AM
fake mugen power
Mar 22, 2005 02:04 PM
FOrSfEd
May 9, 2002 11:59 AM
Integra187
Nov 18, 2001 01:32 PM
