main seal/ oil pump
Old Feb 2, 2004 | 05:14 PM
ViVaLaLude00's Avatar
Default main seal/ oil pump
on a d16y7 does the oil pump have a gasket or is it just a o ring??? we did a vtec head swap in it an blew out the crank seal an are gonna try an change the sealw/o taken off the pump but in case we have to we would like to no if its a gasket or oil pump? or ne suggestions on how to take it out an replace?
thanks
Old Feb 2, 2004 | 05:17 PM
infinatenexus's Avatar
Default Re: main seal/ oil pump (civic2nr97)
on the y7 its just a seal aroung the crank nose. it would be extreamly hard to remove with out taking off the iol pump.
Old Feb 2, 2004 | 05:29 PM
Default Re: main seal/ oil pump (infinatenexus)
is the seal a standard size like could i go get a asortment off o rings?
Old Feb 2, 2004 | 05:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2nr97 &raquo;</TD></TR><TR><TD CLASS="quote">is the seal a standard size like could i go get a asortment off o rings?</TD></TR></TABLE>
No its a seal you have to buy. make sure you lube it before you pound it in
Old Feb 2, 2004 | 05:44 PM
ok i got ya i already ordered it from the honda dealer an they were like it says o ring so i hope it is the right thing
Old Feb 2, 2004 | 05:50 PM
Its the only seal in that area of the motor
Chargerhemi06
Dec 4, 2014 05:43 PM
pjr710
Feb 24, 2009 07:05 PM
heretolearnandteach
Jul 12, 2007 02:12 PM
MugenHonda
Feb 14, 2007 07:04 PM
the.hamburglar
Jul 10, 2006 10:01 PM
