Engine rebuild How To?
Old Feb 1, 2004 | 07:32 PM
3.8turbo's Avatar
Default Engine rebuild How To?
I am looking for tips on rebuilding my D16. Are there any good sites or books i can read up on for tips/tricks or suggestions when rebuilding honda engines?
I have the helms but looking for other sources.
Thanks
Old Feb 2, 2004 | 09:32 AM
1BadCvC's Avatar
Default Re: Engine rebuild How To? (3.8turbo)
All i can say is do it sober and make sure you have proper torque specs...
Old Feb 2, 2004 | 09:36 AM
DC 2's Avatar
Default Re: Engine rebuild How To? (1BadCvC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BadCvC &raquo;</TD></TR><TR><TD CLASS="quote">All i can say is do it sober </TD></TR></TABLE>
Prevent Dumb ****
Old Feb 2, 2004 | 11:19 AM
cannon's Avatar
try to get a helms manuel or the book from honda
Old Feb 2, 2004 | 12:38 PM
Rtype16's Avatar
Default Re: (cannon)
The best book to rebuild your motor is the Honda factory manual. Follow all the steps and you should be all good. I would actually mic the bearings, but plastigauages will work fine.
Old Feb 2, 2004 | 01:24 PM
sweet's Avatar
Default Re: (Rtype16)
it kinda depends on what you want to rebuild this motor for.
it could be just a refresher rebuild for daily stock driving, or it could be for performance and more power. the Helm's/OE manual is good for all the torque specs and general info so that the motor goes together as perfectly as possible, and lasts a long time. but as for performance mods and assembly like P&P heads, manifold work, assembly tips for the most power/longevity, high rpm use, F/I use etc. etc. then you may want to look to the Honda performance handbooks that are out there. i have read some of them and they can be of assistance when building a motor up. you can use the Honda OE manual along with some performance manuals/books to build a good, solid motor. gauging the bearings, checking piston to wall clearances, ring gap and position, torque specs are all standard things that shouldn't be overlooked since they are very important.
Old Feb 2, 2004 | 03:58 PM
3.8turbo's Avatar
Thanks for all your replys. Sweet's reply is what i was looking for. Which Honda Performance Books would you reccomend?
I am rebuilding a D16y8 for boost. This will be a daily driver with a few trips to the track (1/4 mile.) Right now i have a set of 14CC Wiseco pistons and looking to get a set of eagle rods. Power is important to me, but reliability is more important.
Old Feb 2, 2004 | 05:19 PM
sweet's Avatar
Default Re: (3.8turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.8turbo &raquo;</TD></TR><TR><TD CLASS="quote"> Which Honda Performance Books would you reccomend?
Power is important to me, but reliability is more important. </TD></TR></TABLE>
i have read the Volume 1 Honda Performance Handbook that has been around for quite some time now. that was pretty informative overall. i'm not sure about the newer ones including the 2nd Volume. there are various others with more specific topics that i picked up such as Suspension Tuning and Nitrous Injection. also some of the info i've picked up from your average mag, the Tech articles. some are pretty good, but not all. even here on H-T you can find some good info and tips.
it's a good thing you find reliability important, cause it definantly is.
Seatown
Mar 2, 2007 09:32 AM
Akuracy
Dec 27, 2005 01:09 AM
torqueless
16
Oct 30, 2005 09:57 PM
Syphon
Jun 6, 2005 08:18 AM
nd1983
May 5, 2005 12:17 PM
