people running "Joe P. MBC XZ" ... read..
Old Jan 31, 2004 | 01:40 PM
xXx Justin xXx's Avatar
Default people running "Joe P. MBC XZ" ... read..
i have this MBC.. purchased from http://www.boostcontroller.com . it worked great on my old eg. tring to use it on my current turbo ek.. and it is pissing me off b/c it doesnt seem to be working. it worked perfect. sat in the closet. then doesnt work..
i have the end purpendicular <sp> to the adjustor going to the actuator. the end straight under it coming from the vac source (FPR vac) tried loosening it all the way cuz it should run stock spring from the over boost protection right? didnt work... tightened it down a little.. still boosting too high. trying to get it to 8..
any advice? or better yet. anybody that owns this, can you post a pic of the instructions that show me which way the hoses go, and which was turns the boost up/down. TIA
Old Jan 31, 2004 | 05:15 PM
Sinner's Avatar
Default Re: people running "Joe P. MBC XZ" ... read.. (SOHC Beast)
I got that one, I had to reset it today. pos, i worked all day to find the phanton boost leak but it was old joe
Old Jan 31, 2004 | 06:40 PM
sporkcrx's Avatar
Default Re: people running "Joe P. MBC XZ" ... read.. (Sinner)
I have a buddy who used to run that on his sr20det but we found it a lil screwy so he just ended up buying an hks wastegate to adjust boost. I'll try to see if he still has the instructions.
Old Jan 31, 2004 | 08:35 PM
Sinner's Avatar
you want the side that is opisite from the top go come in from the intake. you want the sideways to go to the wastegate.
Old Jan 31, 2004 | 10:26 PM
Default Re: (Sinner)
yea, thats how i had it.... but couldnt figure a way to set it so it would be low boost... there should be a way to start were it will only boost stock spring, then slowly go up instead of guessing and testing, then loosening more....
i even took the screw all the way out and it boosted to at least 10 or so.. i let off then it has an over boost catch on it, so shouldnt that make it run stock spring when it is all the way out?
how are these pressure gauge controllers made, i seen something on it in a search, but not in enough detail to decide if i wanted to go that route.
Old Feb 1, 2004 | 01:26 PM
Default Re: (SOHC Beast)
bump before the superbowl
Old Feb 1, 2004 | 10:59 PM
Sinner's Avatar
if your trying to set the pressure, hook up a T to one side the an air pump, the other side to your boost gauge, work from there. It will get you close, within about +/- 2psi. work from there.
Nick
Old Feb 2, 2004 | 04:50 AM
COOKIEPUSS's Avatar
I believe i have the instructions at home, I have no way of scanningthem, but can fax them to you tomorrow if you'd like. Just give me a fax #, and if I have them, I'll fax them tomorrow.
Old Feb 2, 2004 | 10:43 AM
COOKIEPUSS's Avatar
Default Re: people running "Joe P. MBC XZ" ... read.. (COOKIEPUSS)
If I have them I will fax to the # you gave me, before 5. Anyone's attention?
Oh I can read PM's, but i cannot respond to pm's.
Old Jun 4, 2004 | 10:37 AM
VinceVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">if your trying to set the pressure, hook up a T to one side the an air pump, the other side to your boost gauge, work from there. It will get you close, within about +/- 2psi. work from there.
Nick</TD></TR></TABLE>
Air pump?
Old Jun 4, 2004 | 10:43 AM
hoggy's Avatar
What is your wastegate set at right now without the MBC?
Old Jun 4, 2004 | 11:02 AM
Default Re: (hoggy)
mine was 5.5 stock. but i changed it to about 8.2 or so..
rdeezy78
Aug 27, 2007 03:19 PM
JDMCRX
Aug 15, 2006 02:54 PM
tepid1
Jan 9, 2006 03:33 PM
fro
Mar 11, 2005 11:53 PM
CallMeJesus
Aug 22, 2004 07:13 PM
