Wastegate or MBC leaking / broke.
the problem: I can hold more the 5 psi.
Ive been working all after noon and last night on trying to find a boost leak. Anyway I was doing some search on here and I ran across a post that said remove the line to the wastegate... well when I do that I can boost as much as I push the throttle down. So its either the MBC or the wastegate. What are some good test to figure out which is the cause?
Nick
Nick
here is how I figured it out.
I connected a electric air pump to mbc and the boost gauge, I found it wouldnt let more than 5 psi through so I moved it to to 7 psi where I wanted it.
end of story.
end of story.
B16Civic93
Apr 24, 2005 09:15 AM
technine
Feb 27, 2003 11:50 AM
