What are the risk in buying used cams?
Old Jan 31, 2004 | 12:36 PM
SupaFly_Honda's Avatar
Default What are the risk in buying used cams?
I wanted to know before I buy some used cams. Please enlighten me.
Old Jan 31, 2004 | 12:38 PM
99blackcivicSi's Avatar
Default Re: What are the risk in buying used cams? (SupaFly_Honda)
if thye don't have heavy wear they are fine, check all the journals and lobes for wear and make sure they have been stored properly if they have been out of the car to make sure they are not worped
Old Jan 31, 2004 | 01:26 PM
B18C2_sedan's Avatar
make sure you know what you are buying. Please do a search. Please will scam on ebay
Old Jan 31, 2004 | 02:56 PM
Kendall's Avatar
Assuming that they are straight and don't have a lot of wear, then the only thing to be sure of is if they are indeed the cams that the seller says they are.
Old Jan 31, 2004 | 08:22 PM
Tweakmeister's Avatar
Default Re: (Kendall)
make sure they are packed well and haven't been dropped...stress fractures can occur very easily that will cause breakage down the line.
if you put them in and they break, don't assume it's the cams...could be install error
litterbox
10
Jan 24, 2009 12:10 PM
bonylad
Jul 8, 2006 10:10 PM
4door-r
13
Feb 22, 2004 02:06 PM
Comptech98GSR
Mar 7, 2002 11:48 AM
