Questions About Buying Used Cams?
I am a (Trial User) Army
Hey,
Can you buy cams with high miles (like 50k)? It's not like they wear out or anything right? Also, how do you identify skunk2 stage 2 cams when buying them used?
Thanks.
Thanks.
Re: Questions About Buying Used Cams? (litterbox)
it is weird, because the only time you see cams, they're brand new......I would assume you could buy used ones, i would check the classifieds forum, and/or ebay
not sure about telling the difference, im sure there is a different groove, or skunk2 stamped somewhere
Re: Questions About Buying Used Cams? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Buying used cams is like buying a used heart. I sure as hell wouldn't do it, but that's just me.</TD></TR></TABLE>What's the reason for not wanting to buy used cams? Do they warp over time or anything like that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">What's the reason for not wanting to buy used cams? Do they warp over time or anything like that?</TD></TR></TABLE>
I'll assume the lobes will wear down over time.
Re: Questions About Buying Used Cams? (nota-ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-ex »</TD></TR><TR><TD CLASS="quote">I'll assume the lobes will wear down over time.</TD></TR></TABLE>Can someone define "over time"?
My buddy clubs were used when i got them. As long as the dont have any gouges on them and dont look all worn theyll be fine.
well cams sit on bearings(the head and cam caps) its pretty much like a figer print. every engine has a different wear. you can buy an used cam only if you double check the bearing clearances with plastiguage. if you run a cam which is out of specifications you can basically call your cylinder head junk. i wouldnt buy it used!
Trbospnkr
07-16-2003 04:53 PM
Isaac
08-20-2002 05:52 PM
