running on two cylinders.......help.
Old Jan 30, 2004 | 04:11 PM
elwood's Avatar
Default running on two cylinders.......help.
nevermind........
Modified by elwood at 5:28 AM 2/1/2004
Old Jan 30, 2004 | 05:03 PM
Sliced Beard's Avatar
Default Re: running on two cylinders.......help. (elwood)
are you shure you have your wires connected properly
i just recently switched the number 2&3 cylinder wires by mistake
it is really easy to do, hell i have taken the wires off and on my
dizzy like umpteen thousand times and i just happened to make
a mistake
Old Jan 30, 2004 | 09:36 PM
elwood's Avatar
Default Re: running on two cylinders.......help. (dirtyd463)
Yeah, and just to be sure I had a few other people make
sure I wasnt retarded also.......I wish it was something
so simple!.......sigh..........
Old Jan 30, 2004 | 11:04 PM
boostn420's Avatar
If you can take out 2 spark plugs and have not effect I would do a compression test. That would at least make it easier for the other 2 to rotate.
Old Jan 31, 2004 | 01:41 AM
elwood's Avatar
Default Re: running on two cylinders.......help. (boostn420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">If you can take out 2 spark plugs and have not effect I would do a compression test. That would at least make it easier for the other 2 to rotate.</TD></TR></TABLE>
The first idea on what to do so far..........thanks.
jtrig
Honda Civic (2001 - 2005)
Jun 2, 2015 03:55 PM
andrew__g
Apr 1, 2009 11:11 AM
jr36850
Jul 31, 2007 02:46 PM
JDM00SI
Aug 26, 2005 05:20 PM
jt1583
Jun 19, 2005 03:59 AM
