motor swap questions
Old Jan 29, 2004 | 11:46 PM
ol_dude's Avatar
Default motor swap questions
i have a 92 civic hatch cx and i going to put a jdm d15b vtec engine, tranny, wiring harness, ecu and half shafts in it and i was wondering it i would need motor mounts or anything else with it. i was also wondering how hard of a swap this would be i am an avid car guy and i work in a shop i do all my own brake work and alternaters and such. thanks
Old Jan 30, 2004 | 08:06 PM
boostn420's Avatar
Default Re: motor swap questions (ol_dude)
That swap is so easy. Since the car is 92 I believe the vtec wires are already in your current harness from the computer to the strut so it should all plug in, only I thinkyour jdm harness has the plug on the wrong side. Just use your stock harness and run the wires for vtec from the solenoid the the strut and you should be good.
The axles are the same so I would just use which ever one's look the best.
Old Jan 31, 2004 | 12:32 AM
ol_dude's Avatar
Default Re: motor swap questions (boostn420)
what about if i do with a d16z6 insted of the jdm would it be that easy and would i need a new tranny if i have the 1.5 i figure i will need a new ecu either way but i am try to do this as cheep as posible you know what im saying? thanks
h22rick
Sep 27, 2007 01:12 PM
Boricuanology
Aug 29, 2006 09:21 AM
rohec04
Aug 16, 2005 11:16 AM
rockthegens
Aug 9, 2005 03:32 PM
fasterthenmost
Sep 20, 2002 04:55 PM
