h22 on f22 tranny?
Old Jan 29, 2004 | 07:32 PM
4thgenlude's Avatar
Default h22 on f22 tranny?
ive got an f22 preludewith 144k and i was wondering if the h22 motor will be a direct bolton to my f22 tranny, since i think the f22 tranny has longer gear ratios would it be smart to keep it? or should i just get a full h22 swap
thanx for any help
Old Jan 29, 2004 | 08:21 PM
DrkGreenAccord's Avatar
Default Re: h22 on f22 tranny? (4thgenlude)
It will bolt up, just do not expect it to last long. My f22 transmission lasted about 2 months after the swap. I am not sure what went wrong, but a hole a the size of a penny with transmission oil leaking all over the place is definitely not a good thing.
If you want to save money, you can pick up a h23 transmission. It has longer gearing, but the price is cheaper.
Old Jan 30, 2004 | 07:31 AM
thehondaguru's Avatar
Default Re: h22 on f22 tranny? (DrkGreenAccord)
The f22 will bolt up and if the tranny is in good shape just use it you shouldnt have any problems
Old Jan 30, 2004 | 10:09 AM
Nick M's Avatar
Default Re: h22 on f22 tranny? (95 lude)
dont have *** it, get an h22a tranny
Old Jan 30, 2004 | 10:29 AM
ViZ's Avatar
ViZ
Default Re: h22 on f22 tranny? (Nick M)
there is no reason the f22 tranny would go bad sooner.. its just a different ratio
DrkGreenAccord: i would suspect your f22 tranny wasnt in tip top condition to start out with
Old Jan 30, 2004 | 10:54 AM
SKDRCR's Avatar
Default Re: h22 on f22 tranny? (ViZ)
if your going FI, i would keep the f22 all together,
then after that bites the dust, just get a complete h22
Old Jan 30, 2004 | 06:33 PM
planeman01's Avatar
you'll fall out of VTEC when you shift but it will work no prob. your top speed will be higher i believe but accelleration will be slower.
Old Jan 30, 2004 | 07:04 PM
blklude's Avatar
Default Re: (planeman01)
I had it on my car, it's a gas saver
Old Jan 30, 2004 | 08:09 PM
caLiH22A's Avatar
Default Re: (blklude)
I agree, don't half *** the job, down the line you'll regret it. Unless you plan on going the FI route then I would keep it, but if you want to get the most out of your H22A going NA then get the H22A tranny.
rico892002
Aug 18, 2009 04:01 PM
junlude19
Oct 24, 2004 09:10 PM
o2 jockey
Feb 16, 2004 06:23 AM
juicedh22
Aug 12, 2003 10:29 AM
niedejb
Feb 25, 2002 06:58 PM
