Building motor in a BICYCLE
Old Jan 28, 2004 | 11:05 PM
fe519's Avatar
Default Building motor in a BICYCLE
I am thinking about a project... I want to put a motor in a regular bicycle. The only part I am stuck on is what kind of motor can I get. I am experiementing only and power does not matter at all, I just want to make it work. Do you guys think that a lawnmower engine will work or where can i get my hands on a motor that has a throttle. Thanks. (Anyone actually TRIED this?!?!?!)
Old Jan 29, 2004 | 08:03 AM
rapid_roy's Avatar
Default Re: Building motor in a BICYCLE (fe519)
Use an old weedwacker engine, it's much lighter.
Cheers,
Sean
Old Jan 29, 2004 | 08:31 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fe519 &raquo;</TD></TR><TR><TD CLASS="quote">I am thinking about a project... I want to put a motor in a regular bicycle. ...(Anyone actually TRIED this?!?!?!)</TD></TR></TABLE>
Yeah, like 75 years ago when motorcycles were invented.
Seriously tho, unless you're good at making your own parts, it doesn't sound like a good idea.
The best bet would be the biggest weedwacker engine you can get. Then use the enclosed clutch system. Then all you have to do is find a way to rig it to the chain or wheel.
Old Jan 29, 2004 | 10:40 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Building motor in a BICYCLE (Buzzbomb)
no need for a clutch, use a friction principal to power your bike. it is the same principal a tape machine works, a small roller pressed against a bigger roller, where the bigger roller is the rear wheel and the smaller roller is a shaft off the engine. although i would suspect slip would be an issue.
Stan
Old Jan 30, 2004 | 10:11 AM
fe519's Avatar
Default Re: Building motor in a BICYCLE (Stan D)
but i would a weedwacker engine "move" the bike? I know the speed is not an issue for me but i at least want something with some *****. What is the hp in a weedwacker motor anyways and does it have a throttle?
Old Jan 30, 2004 | 11:01 AM
vtec181's Avatar
dude, they sell those already..is called a motorcycle..and they go faster than your honda..save yourself the money and the time and invested into your car..i work in a bicycle shop...belive me is worth it
Old Jan 30, 2004 | 12:49 PM
rapid_roy's Avatar
Zenoah makes RC engines up to 80cc that put out 5.5-6hp. Yes, that will move a bike. It may not yank a wheelie but once it gets moving it would get along quite nicely.
Cheers,
Sean
Old Jan 30, 2004 | 01:33 PM
Darin D.'s Avatar
Default Re: Building motor in a BICYCLE (rapid_roy)
I've done this before. I put 6hp briggs and stratton side shaft motor on a 3 wheeled old person bike when i was about 12 years old. It was the fastest thing in the neighborhood. I used to race all the kids on those gopeds and go karts. It did about 35mph.
The best motors to use are from weedwackers since they have the drive shaft on the side. Use a centrifugal chain clutch on the driveshaft, but make sure the clutch tooth spacing is the same as the sprocket on your bike wheel. Also, it's important that the motor is attached real solid to the bike frame otherwise the chain is gonna be popping off a lot, unless you made some kind of spring loaded chain tensioner..
Good luck with the project, I used to make stuff like that all the time. It's fun!
PM me if you need any parts, I still have a ton of stuff lying around.
Old Jan 30, 2004 | 02:27 PM
unltdacc12's Avatar
Default Re: Building motor in a BICYCLE (Willis)
Im building something like that. Its more like a mini chopper. Im using a tecumseh 6.5hp engine. supposedly the torque convertor/engine combo im using is supposed to be good for 45-50mph.
Old Jan 30, 2004 | 05:06 PM
yOnKiNaToR's Avatar
Default Re: Building motor in a BICYCLE (unltdacc12)
i wonder if you could use a chainsaw and put in a regular chain and put it right on the sprocket of the bike...you could rig it up to still use the back 5 sprockets to have 5 gears
Old Jan 30, 2004 | 05:16 PM
Sliced Beard's Avatar
Default Re: Building motor in a BICYCLE (yOnKiNaToR)
i did this on one of my spare race frames
it was cool as hell
i had a 6hp ohv go cart engine on it with a custom made clutch sproket (my uncle is a master machinest and i am a welder) that thing was fast as hell.
i took a set of 3 piece cranks and welded the spindle into the frame permanently so i could take the crank arms off and adjust them where needed. i was able to go almost as fast as i could without the engine on the track. hell i was even hitting the triple with it, but let me tell you this, when you crash and the hot *** engine sits on you it is not pretty.
im me if you need any help on doing this
Old Jan 30, 2004 | 05:17 PM
infinatenexus's Avatar
Use a chain saw motor. It has a cluthc,, and has a sprocket already attached.
Old Jan 30, 2004 | 08:45 PM
JDMorgan's Avatar
im takin a cr250 motor and dropping it in my c90....old *** honda bike. i will make it so the gearing is similar to that of the cr250 so i can smoke the tire down the road thru 2 gear and should be doin 80-90 top speed. i doubt it will be done any tmie soon tho, using a stock tuned pipe frmo the c90. looks sweet. fresh honda red paint. i really like the "mini-chopper" tho, very unique
Old Feb 6, 2004 | 04:16 PM
fe519's Avatar
Default Re: (KraZEtEggIE)
do you think a chainsaw motor will work best? Also, how many hp do you think it takes to get the bike moving. Im going to try this on one of my ghetto bikes from Target so its pretty heavy.
Old Feb 10, 2004 | 07:34 PM
fe519's Avatar
Default Re: (fe519)
does anyone know if a chainsaw motor would work? because a weedwacker engine has about only 1-2 hp while a chainsaw 3-5 hp. I checked out some pictures and it seem as if it will work on a bicycle. also, how are a chainsaw engine and a weedwacker engine different or is their setup about the same?
Modified by fe519 at 4:45 AM 2/11/2004
Old Feb 11, 2004 | 07:15 AM
unltdacc12's Avatar
Default Re: Building motor in a BICYCLE (NAPA182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPA182 &raquo;</TD></TR><TR><TD CLASS="quote">Hey post more pics of your bike.It looks good </TD></TR></TABLE>
thanks.. heres a few more
Old Feb 11, 2004 | 01:22 PM
fe519's Avatar
anyone knows the difference?
nvmeplz
135
Dec 29, 2006 03:20 PM
vtecstudent
Jun 22, 2006 05:20 AM
EJ8 GSR-T
May 6, 2006 12:27 PM
hks3630
Dec 8, 2003 06:29 PM
prdtr15
20
Oct 7, 2003 10:47 PM
