Finally turbo!!! Now I got a problem
Old Jan 28, 2004 | 03:28 PM
booscivic's Avatar
Default Finally turbo!!! Now I got a problem
I have a SOHC d16z6, after finishing my install the car is hard to start when cold. I have change spark plugs and lower fuel, any suggestions what it may be?
Set Up:
d16z6 stock bottom end(ARP head bolts and mr gasket head gasket) 7psi
t3/t4b
ngk bk7re .30
3"dp
hondata S100(untuned)
bbk fuel pump
450cc
AEM fpr
greddy type s BOV
rev hard manifild and fmic
AVCR
all kind of guages
nology ignition amp
tial wg
Also running open dp!!! for now
Old Jan 28, 2004 | 03:43 PM
Jared's Avatar
Default Re: Finally turbo!!! Now I got a problem (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic &raquo;</TD></TR><TR><TD CLASS="quote">
that sounds like the problem
Old Jan 28, 2004 | 03:47 PM
booscivic's Avatar
Nah!!! It started just find at first with time is getting worst
Old Jan 28, 2004 | 03:48 PM
10seceg's Avatar
1) injectors
2) plugs
3) prolly downpipe (might not have enough back pressure)
just my .02 of what it could be
Old Jan 28, 2004 | 03:49 PM
booscivic's Avatar
Thanks, Im thinking of changing the gap an lowering fp a little bit more
Dee's Avatar
Dee
Default Re: Finally turbo!!! Now I got a problem (Jared)
Do you have a good base map? The base map is only used to get you to a tuner or to start the car so you can tune it yourself.
DaX's Avatar
DaX
Loved
Community Favorite
the untuned hondata is probably the culprit. things can mysteriously go wrong over time with an untuned ecu. remember...the ecu is constantly making adjustments, and over time, it could adjust itself right out of it's ability to operate.
Old Jan 28, 2004 | 03:53 PM
booscivic's Avatar
Im waiting to get my 3" exhaust to get it tuned!
Old Jan 28, 2004 | 03:56 PM
booscivic's Avatar
Anybody else? what amount of fuel pressure should I be running with 7 psi?
Old Jan 28, 2004 | 04:00 PM
BoostedD15B7's Avatar
Im not sure if you mean hard to start when the engine is cold, or hard to start when the temperature outside is very cold. If you talking about outside temp if may be your fuel mixture. In real cold weather, you need alot more fuel to crank the car.
Old Jan 28, 2004 | 04:03 PM
booscivic's Avatar
Default Re: (BoostedD15B7)
maybe I need to raise the fuel? Yes outside temp
Old Jan 28, 2004 | 04:15 PM
racinskittle's Avatar
Default Re: (booscivic)
does hondata support 450's? i didnt think they did.????
Old Jan 28, 2004 | 04:20 PM
booscivic's Avatar
They can set that base map pretty much how ever they want!!!
Old Jan 28, 2004 | 05:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic &raquo;</TD></TR><TR><TD CLASS="quote">They can set that base map pretty much how ever they want!!!</TD></TR></TABLE>
So what? I have a feeling you dont believe me on this one. SOOO read the link. Actually sounds very similar to your problem
http://hondata.com/bb/viewtopic.php?t=432
"DSM 450cc injectors will not work with the Honda ECU - the electrical characteristics of the injector are not suited to the ECU, resistor box or no resistor box.
If you use DSM 450cc injectors you will find the engine difficult to start, and the engine running lean at part thottle, plus tuning is very difficult. "
-Hondata
Old Jan 28, 2004 | 05:50 PM
FlaN.'s Avatar
^^ that's probably your problem.
Old Feb 1, 2004 | 06:56 PM
booscivic's Avatar
Anybody else? IT just when the engine is cold
93TurboSi
Aug 19, 2010 07:52 PM
ssbigpimp8606
Aug 13, 2009 08:08 PM
important
Oct 13, 2007 07:26 AM
pa2play
Nov 12, 2005 10:00 PM
BoostedH23a1
Nov 7, 2004 10:31 AM
