Vtec engagement problem
Old Jan 28, 2004 | 03:27 PM
T.J.'s Avatar
Default Vtec problem
The other day I went out to run some errands and my car was running fine. Come home wash the car sit around for about 3 hours and go out again. While driving I then notice that my Vtec was not engaging. I go home try and figure out the problem. I change out Vtec solenoid's , check my oil , speedometer works but i checked the vss anyways. Still nothing at all but wasn't sure what else to check for. So this past weekend i take the car and put it on the dyno and play with the EMS and see if we can figure some things out and get some answers. Played with some fuel still nothing, Then went to play with high and low cam vetc settings. Found out that vtec would engage at low cam but not high . Pretty much determined it was a mechanical problem in the head. My question is what could be the problem im not sure exactly what im looking for when i pull the head or every thing I need to check for.
The set up is a obd2, gsr block , ctr pistons, arp rod and head studs, OEM 3 layer head gasket, b16 head port and polish , jun springs , jun retainers, jun 3 cams , and cam gears are set at zero. Any help would be most appreciative Thanks.
Modified by Skunk2whore at 9:29 AM 1/31/2004
Modified by Skunk2whore at 9:31 AM 1/31/2004
Old Jan 28, 2004 | 03:57 PM
keebler65's Avatar
Default Re: Vtec engagement problem (Skunk2whore)
make sure you have enough oil in your car. there are also other variables as well. someone did a nice writeup a while back that said everything to check. maybe do a search because this is a common problem.
Old Jan 28, 2004 | 09:52 PM
T.J.'s Avatar
Default Re: Vtec engagement problem (keebler65)
yeah i did some serching but couldnt realy find what i was looking for.
Old Jan 28, 2004 | 10:09 PM
C8V6C's Avatar
If everything is good, check the ecu ports for your vtec ****
If something is loose or a **** soldered job, it could be as simple as that
Old Jan 29, 2004 | 10:58 AM
T.J.'s Avatar
Default Re: Vtec engagement problem (C8V6C)
not an ecu problem anybody else
Old Jan 29, 2004 | 12:24 PM
POE's Avatar
POE
once my battery was sittin on top of my vtec wires i put in and was cause it to ground out and i was thowing a code for no vtec... maybe check the wires.
Old Jan 29, 2004 | 05:27 PM
T.J.'s Avatar
Default Re: (Vtecin94dx)
yeah ive checked the wires and everything but the thing is im not throwing a cell for no vtec
Old Jan 29, 2004 | 05:38 PM
mattssi's Avatar
Default Re: (Skunk2whore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2whore &raquo;</TD></TR><TR><TD CLASS="quote">yeah ive checked the wires and everything but the thing is im not throwing a cell for no vtec</TD></TR></TABLE>
These are all signs off not enough oil pressure? What kind of oil filter do you have? Have you done any mods lately since this has happened?
Old Jan 29, 2004 | 05:44 PM
T.J.'s Avatar
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">
These are all signs off not enough oil pressure? What kind of oil filter do you have? Have you done any mods lately since this has happened?</TD></TR></TABLE>
Im using A honda filter and no mods lately at all
Old Jan 30, 2004 | 12:54 AM
T.J.'s Avatar
if it is a low oil pressure problem, what do i need to check for that can cause the oil pressure being low?
Old Jan 30, 2004 | 09:00 PM
T.J.'s Avatar
anybody else i need help fast
Old Feb 10, 2004 | 06:03 PM
Stunna BEN's Avatar
Don't call it a comeback
Bump, theres gotta be help somewhere.
cmwalker
Oct 25, 2012 08:53 PM
jdm.boi408
Nov 26, 2010 09:53 AM
T3k C
Mar 19, 2007 02:22 PM
blowme
19
Apr 25, 2005 07:00 AM
TURBOFTW
Apr 3, 2004 05:06 AM
