how to distinguish civics/integras knuckles...
is there a part number on the knuckle ... any1 have info? links etc ...
note : i just have the knuckles and nothing else .. i need to find out if they are civics or integras
started this post on the eg forum but no1 knows
https://honda-tech.com/zerothread?id=748590
well the hub on a integra knuckle is larger than most civic knuckles besides from the i think 93-95 civic si and a 94-95 civic ex 2 or 4 door
the stud location on the integra or the civic hub is about an inch from the outer edge
with a standard civic hub/knuckle you are able to remove the studs without getting the hub pressed off
on an integra or the noted civics, you have to get the hub pressed off to remove the studs
i dont know the part numbers off of the top of my head otherwise i would help you out with that
also the caliper mounting piont is farther out on a integra and noted civics
Sifu
Apr 26, 2006 12:24 PM
spoolingb20
Nov 28, 2005 05:47 PM
