Could use some help please
Old Jan 27, 2004 | 09:25 PM
88 turbo crx's Avatar
Default Could use some help please
Well i got the new obd1 gsr distributor today for my ls vtec... ever since i tried to use the sohc vtec dizzy which my car didnt start with the actual turning of the motor via the starter sounds wierd.. sounds almost like a dead battery(i tried to different batteries and charged them both with cables)... its like a constant slow turning(whiny sound) Anyways im wondering if incorrect distributor wiring could have done anything or if my main relay or anything is bad... The car has run in obd0 form with this motor installed so it should be cool... When i checked the distributor and the wires to see if i was getting a spark... it didnt appear to work... i have it all color matched and according to my conversion harness the two white wires can be interchanged as they both go to the same wire..
But anyways.. any input would be great to get this thing started..
Old Jan 28, 2004 | 07:34 AM
Default Re: Could use some help please (88 turbo crx)
ttt
Old Jan 28, 2004 | 11:52 AM
JunkMall1984's Avatar
check all the connections to the starter? sometimes, the 'remote' wire to the starter is not connected correctly.
Old Jan 28, 2004 | 04:13 PM
Default Re: Could use some help please (JunkMall1984)
if its not connected correctly it wouldnt turn at all right?
mike
Old Jan 28, 2004 | 05:01 PM
10seceg's Avatar
or...it might just be a bad starter...IMO
coltonbarrier
Dec 24, 2013 05:53 AM
gunnerman
May 20, 2009 04:54 PM
Timmyflys
10
Nov 17, 2006 03:02 PM
Eggman
Nov 22, 2001 11:51 PM
