B16 Timing Belt on LS??
Old Jan 27, 2004 | 05:55 PM
obie2102's Avatar
Default B16 Timing Belt on LS??
Ok, i'm putting an LS motor in my 92 CX hatch, and I've already got a B16 timing belt (that was originally for my 99si), GSR Water pump and STR cam gears. A shop in my area told me that as long as i change my water pump that belt would fit. Well i put the STR cam gears on, put the water pump on, and the belt does not fit. To me it does not seem long enough. When they told me the B16 belt would fit, i thought i would have to use a gsr belt because i thought that B18 blocks were physically taller. Is this the case or do i just need to try harder? Thanks in advance.
Old Jan 27, 2004 | 07:17 PM
pro1342's Avatar
You should have ran a LS water pump and belt.
Old Jan 27, 2004 | 08:00 PM
obie2102's Avatar
I already had everything before i bought the motor, so why not use it. I've figured out that all i need is the GSR belt.
Old Jan 27, 2004 | 11:15 PM
mmuller's Avatar
Mad Scientist
Default Re: (obie2102)
vtec timing belt= vtec water pump(22t)
non vtec timing belt= non vtec water pump(19t)
But you'll need a b18c timing belt since the b18 and b16a blocks have different deck heights
Old Jan 27, 2004 | 11:28 PM
onesikviet's Avatar
Default Re: B16 Timing Belt on LS?? (obie2102)
use whatever timingbelt that goes with the waterpump, ie ls pump=ls timin belt/ gsr pump=gsr timngbelt
Old Jan 28, 2004 | 01:54 AM
dwayne.eaddy's Avatar
Default Re: B16 Timing Belt on LS?? (onesikviet)
i did the same thing when i built my ls/vtec the b16 timing belt will fit but it is tight and will have hissing sound (it might brake after a while but i don't know i have put 300 miles on my car in 2 years it just a toy for me.). get a gsr timing belt it fit like a glove
rick_rabies
Apr 1, 2009 12:59 PM
GearheadzAuto
Jan 3, 2008 07:58 AM
EFOSV
Jun 16, 2004 07:22 PM
infamousALLMTR
Feb 25, 2003 07:16 PM
Boost2NA
Oct 31, 2002 03:36 PM
