Best single cam non vtec head?
Old Jan 22, 2004 | 02:58 PM
hatchback19's Avatar
Default Best single cam non vtec head?
Just looking for some ideas of what you guys think is the best non vtec head? Im debating between the a6, y7 and b7. I can use the B7 off of my car now for my d16z6 bottom end but I was wondering what timing belt I'd use. Thanks for your help,
Matt
Old Jan 22, 2004 | 04:45 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: Best single cam non vtec head? (hatchback19)
if im not mistaken the a6, b2, and b7 are the same casting...just different cams and valvetrain. i know the a6 and b2 are the same and i <u>think</u> the b7 is too. the y7 has a smaller combustion chamber...same size as z6 (so i would assume they are similar castings...but again i am just guessing on that) and also 1mm bigger valves. not that that will help much on the 75mm bore size.
ive always read as a general rule of thumb to use the timing belt for the head your gonna use. ie...a6 block z6 head = z6 timing belt. but ive never tried it so better get more feedback first.
as for which ones the best???
Old Jan 22, 2004 | 07:35 PM
Default Re: Best single cam non vtec head? (fastcrxsi90)
Thanks for the reply, its a 78mm bore if that makes any differance.
Old Jan 23, 2004 | 10:49 AM
anymore?
Old Jan 23, 2004 | 10:54 AM
Sobe_Death's Avatar
i always thought the y7 head was still vtec, just vtec-e, while the y8 was reg. vtec. ive seen some mad power numbers come from an a6 head, but i dont know.
Old Jan 24, 2004 | 05:31 AM
civic-4-ges's Avatar
Default Re: (Sobe_Death)
Y7 is definately not a Vtec head or a Vtec-E head
Old Jan 27, 2004 | 04:23 PM
BauleyCivic's Avatar
Risky Business
Default Re: (civic-4-ges)
A6 and B7 are both the same casting...
use the B7 with the Z6 bottom, but make sure you use the B7 belt
Old Jan 27, 2004 | 08:33 PM
thanks for the info
Old Jan 28, 2004 | 02:00 AM
myinvestedagony's Avatar
Default Re: (hatchback19)
if you want best stock setup go with the A6 head but if you are rebuilding it then it doesnt matter B7 and A6 are identical with the new generations have the Z6 casting but without Vtec and a smaller combustion chamber depends on whether you want more compression or not.
DCRB
Sep 28, 2009 08:59 AM
Ocnaj
10
Jun 14, 2008 09:38 AM
jdmegcivic95
Aug 11, 2005 06:06 AM
SOHC_MShue
15
Jun 3, 2005 06:18 PM
MrPotatoeHead
Jan 16, 2005 10:35 AM
