IDLE problem? please help
Old Jan 27, 2004 | 11:47 AM
vxhatch02's Avatar
Default IDLE problem? please help
i just got a 95 vx hatch with the 1.5 vtec-e engine and it runs fine but when ever i stop the idle gos up and down between 500 and 1500 rpms some time... i changed the pcv valve thinking that was the problem but no and i used some seafoam but if anyone has any sugesstions on what to check or replace please let me know... thanks
Old Jan 27, 2004 | 11:58 AM
92civeg's Avatar
Default Re: IDLE problem? please help (vxhatch02)
icav, fitv, tps, air in coolant
Old Jan 27, 2004 | 11:59 AM
InjectedPerformance's Avatar
We sell parts.
The problem is the idle air control valve. Remove it from the intake manifold and inspect it. Either the screen is clogged or the spring inside has broke.
Old Jan 27, 2004 | 01:35 PM
vxhatch02's Avatar
Default Re: IDLE problem? please help (primo8998)
thanks alot i will check that and get back too you.. thank
Old Jan 27, 2004 | 02:29 PM
vxhatch02's Avatar
is there anything else i should check
Old Jan 27, 2004 | 02:45 PM
We sell parts.
It did not work? Bleed your system maybe u have an air bubble in there.
Old Jan 27, 2004 | 05:29 PM
92civeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxhatch02 &raquo;</TD></TR><TR><TD CLASS="quote">is there anything else i should check</TD></TR></TABLE>
i guess ill say it again......fitv,tps,air in coolant
Old Jan 27, 2004 | 08:33 PM
H22CL's Avatar
what if car idles smoothly, but when I rev it slowly, when it gets to 1500 rpm, it starts to jump? it only jumps when I rev it slowly while in neutral, if I rev it fast it just flys right but 1500 rpm. It's a pain in the *** to start off from a light without reving it very high. Again car idles like a sleeping baby!
civc_tt
Jul 30, 2006 11:00 AM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
DubyaAye
Mar 7, 2005 06:33 AM
E-spec Tuner
May 29, 2004 10:30 AM
97AccordLx
Jun 9, 2002 05:44 AM
