O-Ring In Head and Bottom Of Motor (Oil Girdle)?
Old Jan 27, 2004 | 09:14 AM
LudeyKrus's Avatar
Default O-Ring In Head and Bottom Of Motor (Oil Girdle)?
I just now thought about the two o-rings I remember reading about. There is one under the center cam cap that I can easily get to, but where is this one that's supposedly in the oil girdle? I remember reading about an o-ring somewhere below the crank that is necessary, but can't find a pic or anything about it. Does anyone know which one i'm talking about?
Old Jan 27, 2004 | 09:23 AM
PrecisionH23a's Avatar
Default Re: O-Ring In Head and Bottom Of Motor (Oil Girdle)? (LudeyKrus)
The small one that is inside of the oil pump assembly?
Old Jan 27, 2004 | 09:38 AM
LudeyKrus's Avatar
I don't think so; I found the one in the head, it's got the little round groove that it sits in under the center cam cap.
The one I'm thinkin of I believe is between the oil girdle and the main caps; i was just lookin at my busted H23 girdle, and there's a similar groove for what may be an o-ring between the center of the girdle and the main caps, but the groove is much deeper than the one in the head.
I just remembered someone saying there's an o-ring in the bottom of the block somewhere....and I'm afraid I may of forgot it.
Old Jan 27, 2004 | 09:46 AM
Default Re: (LudeyKrus)
A picture might refresh my memory...
Old Jan 27, 2004 | 10:08 AM
LudeyKrus's Avatar
Default Re: (PrecisionH23a)
The center dowel pin on the center main cap is not there; instead there is a round groove for what looks like may be the o-ring. I'm not sure an o-ring goes there, hence my asking the question.
Old Jan 27, 2004 | 10:12 AM
Oh **** man... it looks like you are going to have to tear the motor apart and put those o-rings in.
.....sike
you are fine
Old Jan 27, 2004 | 10:16 AM
LudeyKrus's Avatar
What a punk.....
If it's not a big deal then, why did Honda not put another dowel pin on the center one, like all of the other end caps?
I've already tore the bottom end down once to check on something, I was gonna be pissed if I had to do it again!
Old Jan 27, 2004 | 10:25 AM
Fly1865's Avatar
number 46
Old Jan 27, 2004 | 10:28 AM
Default Re: (Fly1865)
Well if he didn't take apart the girdle he should be fine... right?
EG6_978
Nov 19, 2009 06:03 PM
pullin crx hf
May 12, 2009 08:13 AM
Civiclized
Sep 22, 2005 12:10 PM
BEEYOND
Sep 1, 2004 09:06 PM
Evil EG
Jan 22, 2003 06:45 AM
