a specific problem....tranny
Old Jan 26, 2004 | 05:44 PM
nd8ch's Avatar
Default a specific problem....tranny
1. i hear a light sound in neutral, engine running and not moving and clutch out
i can only hear the sound when i listen for it (radio off)
2. the sound stops when i push the clutch in
3. when i drive, i hear a whirr sound between 1k-4krpm, loudest 1st gear, and
gets quieter 2nd and 3rd and on its hardly hear-able
4. when im crusing; in any gear with the clutch in, there is no sound
5 when cruising; with the clutch out and in gear, the lower the gear the louder
the whirr, but not as loud as actually accelerating
6. when im cruising (50mph); in 2nd or 3rd (louder in lower gears still),
and with the clutch in and gradually letting go the clutch
(so the rpm climbs to vehiclespeed) the car makes a high pitched
whine, not loud, but very noticable untill the rpms match vehicle speed
ok...so some people say its the throw out bearing, some would say the input shaft bearing...im thinking its not the input shaft cause with the car moving in gear with the clutch in, the gears are all moving. but it doesnt make sense to me to be the TObearing, cause it should make more noise with the clutch in if it were bad?
I checked the tranny fluid, and it was still orange, no particles came out or anything, seems like healthy fluid, and it was topped off too, no leaks anywhere.
Old Jan 26, 2004 | 06:20 PM
hondatim's Avatar
Default Re: a specific problem....tranny (nd8ch)
Sounds just like mainshaft bearing to me. Yes, trans will still operate even though bearing may be totally damaged. I'd suggest pulling trans and replacing all 7 bearing and also install new TO bearing before putting back in car. But from description, definitely sounds like mainshaft bearing is failing.
Old Jan 26, 2004 | 06:26 PM
nd8ch's Avatar
Default Re: a specific problem....tranny (hondatim)
thanks, but i still dont get why its the mainshaft bearing, if the gears are still running when i drive in gear with the clutch in. i figure it will always make a sound when in gear
and no noise comes from it when im moving in gear with the clutch in.
my oil looked really good though, like i just put new oil in there.
Old Jan 26, 2004 | 06:35 PM
hondatim's Avatar
this is typical and just seems to be how the act. i have seen a lot of guys mistake this bearing noise for the TO bearing only to get trans out after selling clutch job and find mainshaft has excessive runout caused by bearing failure. Or worse yet, not catch the bearing failure while trans was out, get trans installed and find out that noise is still there. Very hard to sell to customer, or worse yet tech having to eat the labor to perform same job twice!
Even though you push in clutch, with car still in gear and rolling, there is no load on mainshaft, this is why noise goes away at that time.
But you say that when driving and downshift to lower gear, noise increases in pitch and intensity? Definitely mainshaft bearings.
Also, don't scrimp and only install that bearing. You need to replace all 7 bearings otherwise you'll just be pulling it again later to do same job again.
Old Jan 26, 2004 | 07:35 PM
nd8ch's Avatar
ok. thanks for you input
now, how much is it to replace all the bearings
and how much additional for syncros? i think my 2nd gear syncro is going, i can hear something when i just press it in the 2 pos without the clutch, i hear a spinning sound
Old Jan 27, 2004 | 01:36 AM
Mista Bone's Avatar
D Tranny Guru
Si/EX S20/L3 trannys
Input shaft bearing........91002-PSO-003 $17.37
ISB seal ......................91216-PL3-005 $ 3.92
ISB spring washer.........23927-PL3-000 $3.15
ISB spacer washer........23928-PL3-000 $3.59
I just ordered 5 sets from http://www.slhonda.com
I charge locals $80 if the tranny is brought to me, including parts.
Old Jan 27, 2004 | 09:56 AM
nd8ch's Avatar
Default Re: a specific problem....tranny (Mista Bone)
you think my car will make it to the next autox practice event in feb 7?
or is it too risky?
Old Jan 27, 2004 | 12:07 PM
Mista Bone's Avatar
D Tranny Guru
look at this folder..........
you tell me if it is worth risking it........
http://www.bettendorf.com/~mrb...0ever/
Old Jan 27, 2004 | 12:38 PM
nd8ch's Avatar
all because of a bad bearing? yikes!!
man...if i get my clutch done next week, i dont know if i can break in my clutch in time...how long are i supposed to break in the clutch for?
Old Jan 27, 2004 | 05:48 PM
Mista Bone's Avatar
D Tranny Guru
you won't get your clutch broke-in in time.
Old Jan 27, 2004 | 06:49 PM
nd8ch's Avatar
about how much would it cost for a mechanic to replace the main bearings in the tranny? if i deliver the car though.
Old Jan 27, 2004 | 08:00 PM
Mista Bone's Avatar
D Tranny Guru
3 hours R&R
3 hours for the tranny inspection
1 hour for the ISB
7 hours at $70 a hour = $490 + parts.
Learn to do it yourself.
Sheot, even Bauley could do it himself, with alot of internet help from me!
Old Jan 27, 2004 | 09:02 PM
hondatim's Avatar
Again. Don't just replace mainshaft bearing. You need to replace all 5 shaft bearings and both final drive carrier bearings. Also need to replace both axle seals and mainshaft front seal.
If you looked at the link to the trans pictures above, you will understand that all bearings should be replaced. Not just one. i have rebuilt literally hundreds of honda trannys and it always seem trannys spread pieces of bearing cage throughout entire trans. These pieces have a tendency to get lodged into other bearing cages, causing premature wear of other bearings if not replaced.
just word to wise...
Old Jan 27, 2004 | 09:12 PM
nd8ch's Avatar
where can i get the final drive gear? maybe i should jsut get that changed aswell, how much ar ethey if they make them?
Old Jan 27, 2004 | 09:24 PM
hondatim's Avatar
shouldn't need final drive gear. just bearings. unless of course you're talking about changing final drive gear to different gear ratio. but shouldn't need any gears for just replacing bearings.
Old Jan 27, 2004 | 10:53 PM
nd8ch's Avatar
yeah, i was thinking maybe i should change the ratio if its not too expensive and attainable.
Old Jan 28, 2004 | 02:31 AM
Mista Bone's Avatar
D Tranny Guru
$500 + labor to chanmge the FD ratio to a SRR unit.
Old Jan 28, 2004 | 10:01 AM
nd8ch's Avatar
Default Re: (Mista Bone)
wow...didnt expect that coming
what other things besides lsd can i do while the tranny is open?
Old Jan 28, 2004 | 12:17 PM
lovitalracer's Avatar
Default Re: (nd8ch)
That just sounds like a throw out bearing .. Change that and you should be fine .
It's about 50 bucks
Old Jan 28, 2004 | 08:11 PM
nd8ch's Avatar
Default Re: (lovitalracer)
im pretty certain its a tranny problem...i was coasting down a hill today in 2nd gear at about 40-50 mph with the clutch in, and i can hear a whine sound in the tranny. the sound's intensity is relative to vehicle speed, if i pull the shifter to neutral, the sound goes away. and the clutch has nothing to do with this situation execpt when the clutch is engaged in gear, the sound just sounds different in the gears assuming its the same problem with a load on the bad bearings.
thanks for all your help guys, i called my mechanic and he said he'll replace the bad bearings and seals for 600+parts, since a new tranny doesnt garauntee a good working tranny
Old Jan 28, 2004 | 08:38 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Learn to do it yourself.
Sheot, even Bauley could do it himself, with alot of internet help from me!</TD></TR></TABLE>
Yep!!! I love you chip
Old Jan 28, 2004 | 11:50 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (nd8ch)
Better off to learn how to do the work yourself.
$600 + parts??????
I guess I should raise my prices.
For $600 you could get 3-4 trannys...........
Old Jan 29, 2004 | 06:40 AM
Dan GSR's Avatar
Default Re: (nd8ch)
if your good with working on cars do it yourself
its like $70 in parts
and its def the input shaft bearing
https://honda-tech.com/zerothread?id=596873
Old Jan 29, 2004 | 09:52 AM
nd8ch's Avatar
Default Re: (Dan GSR)
id love to do it myself, but i dont have the time right now, and its my primary driver....they day will come when i truely fiddle with my car
where can you get a good running tranny for less than 400?
osix
Dec 13, 2015 08:28 AM
Koko4
17
Jul 17, 2013 07:03 PM
scottybfh
14
Sep 27, 2006 09:07 AM
nd8ch
31
Jan 28, 2004 10:03 AM
mgf163
Apr 24, 2003 09:24 AM
