problem with chipped ecu
Old Jan 26, 2004 | 03:28 PM
Jagolas's Avatar
Default problem with chipped ecu
i have a p28. just chipped it like two days ago. i can't rev pass 4k and check engine light is on. have i royally screwed up? i just cut the j1 jumper hoping that it will now work right. also will a venom control module make the vtec act up? my car seems sluggish even with a custom 2 1/2 exhaust with 4-2-1 ceramic coated headers, a high flow cat, cold air intake, apc wires, and ngk vpower plugs. any info is greatly thanked.
Old Jan 26, 2004 | 05:12 PM
Jim Truett's Avatar
Default Re: problem with chipped ecu (jagolas)
The ECU is in limp mode because there is a problem with the chip or the soldering. Can you take a picture of both sides of the ECU and post it here? The 2 1/2 inch exhaust and the CAI will make a stock engine seem sluggish because you will lose low end torque. Check the resistance of the plug wires. Remember APC=Another Piece of Crap.
Old Jan 26, 2004 | 06:23 PM
Jagolas's Avatar
Default Re: problem with chipped ecu (Jim Truett)
i would take the pics, but my digital camera is down. i think it was the soldering, but if i cut the j1 jumper will it go back to norm? i will just have to take it to someone who can solder a lot better than me. it may just need to have the solder gone back over it. and even though i lose the low end i really don't pick up much top end, not to mention i have been having prob with the plug and the 3rd cylinder. i have fouled it maybe 2 or 3 times and i have ran colder and hotter ngk plugs. so i think it may be a combination of the rotor button, dist cap, and the wires. thanks
Old Jan 26, 2004 | 06:30 PM
hondatim's Avatar
If you cut J1, yes, should revert back to stock program.
Old Jan 26, 2004 | 06:35 PM
Jagolas's Avatar
Default Re: problem with chipped ecu (hondatim)
thanks i just cut the wire that was in j1 hopefully i can test it out before i go to work tomorrow. next time i go to a pro to get it soldered and watch them.
Old Jan 26, 2004 | 06:42 PM
hondatim's Avatar
you definitely need proper equipment in order to solder printed circuits.
Vtec140
Oct 3, 2017 02:15 AM
manasel
Engine Management and Tuning
Feb 4, 2015 06:32 AM
4ghatch
May 2, 2008 11:34 PM
racerzedge
Jul 27, 2005 08:57 AM
ls95hatch
Jul 17, 2003 02:13 AM
