searched stock sleeves and didn't find out what kind of compression people run
pretty much hope to max out the 18G at about 330-350whp on stock sleeves. should I go lower compression(8.8:1) or higher (9.6:1)
also with gettin a clean hone on the cylinders make it require 81.5mm pistons? I would like to keep it stock bore but if I have to I will bore it a bit.
Or last but not least just stick with the inline pro head gasket and block gaurd and boost it till it blows on stock internals and then sleeve it?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedITR41 »</TD></TR><TR><TD CLASS="quote">pretty much hope to max out the 18G at about 330-350whp on stock sleeves. should I go lower compression(8.8:1) or higher (9.6:1)
Or last but not least just stick with the inline pro head gasket and block gaurd and boost it till it blows on stock internals and then sleeve it?</TD></TR></TABLE>
stick with the inline pro headgasket...tuned well i think it will last quite a while @ 350whp..
what type of management are you running? If you are using an fmu or afc I would lower compression a bit, if you have something you can really tune with stay stock. You shouldnt have to get oversize pistons for a clean hone, they should remove minimal material if they do it right.
I have 84k miles on the motor I am just worried that the HG won't do well for one more year.
I have a hondata 4B ready to go in the car with precision 945cc injectors
for only 350whp keep the sleeves stock. Blockguard isn't required. Get the new headgasket and run the 9.6:1 if its going to be fully tuned.
i would strongly suggest running your compression @ 9:1. avoiding detonation is one of the key elements to running stock sleeves successfully. IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 »</TD></TR><TR><TD CLASS="quote">i would strongly suggest running your compression @ 9:1. avoiding detonation is one of the key elements to running stock sleeves successfully. IMO.</TD></TR></TABLE>
that's what I was thinking the lower the compression the less chance of detonation.
well thanks for the replys guys
BtMplayboi
Feb 11, 2005 03:00 PM
