Is there a way to check if a motor is stolen ?????
Old Jan 26, 2004 | 08:18 AM
silverEH2's Avatar
Default Is there a way to check if a motor is stolen ?????
anybody know how to check on tranny #s and block #s......i found a good deal but i wany peace of mind......i dont deal with stolen ****
Old Jan 26, 2004 | 08:23 AM
Quad-Damag's Avatar
Default Re: Is there a way to check if a motor is stolen ????? (silverEH2)
it should have legel papers and run the vin number at a local honda dealership or ask a firend in law in forcement, make sure u have a legel agreement that it is a legel motor with paper work and vin numbers and have him sign over the motor to you, so it's legely yours, better safe then sorry, i did that for my tranny when i sold it.
HondaCutter's Avatar
if the VIN's are still on the motor, you could probably run a carfax report on them and see if the car that it belonged to was stolen. I'm not sure what information the carfax reports cover, I've never used it. But I would think something like that would show up. If the VIN's are not on the motor or tranny, then I don't know.
Old Jan 26, 2004 | 08:25 AM
Quad-Damag's Avatar
Default Re: Is there a way to check if a motor is stolen ????? (HondaCutter)
If the Vins are not on the motor it's not a JDM Motor, i would lean to stolen, and he filled off the numbers
Old Jan 26, 2004 | 08:31 AM
silverEH2's Avatar
Default Re: Is there a way to check if a motor is stolen ????? (Quad-Damge)
do the numbers on the motor and tranny match to the vin of the car though
Old Jan 26, 2004 | 08:58 AM
Mr Boston's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">do the numbers on the motor and tranny match to the vin of the car though</TD></TR></TABLE>
Yes both vins on the motor and tranny should match the body of the car
Old Jan 26, 2004 | 08:59 AM
BauleyCivic's Avatar
Risky Business
Default Re: Is there a way to check if a motor is stolen ????? (Ngo Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ngo Power &raquo;</TD></TR><TR><TD CLASS="quote">
Yes both vins on the motor and tranny should match the body of the car</TD></TR></TABLE>
Yep Tom (B18C5-EH2) I believe has the title for the wrecked ITR that his motor came out of
Old Jan 26, 2004 | 09:12 AM
silverEH2's Avatar
Default Re: Is there a way to check if a motor is stolen ????? (BauleyCivic)
ok so will a carfax report work, at this point
Old Jan 26, 2004 | 09:15 AM
SlepT ej6's Avatar
the vin # on the motor will only match the vin # on the car if that motor came stock in that car, if it was swapped into it, it will not match!
Old Jan 26, 2004 | 09:19 AM
silverEH2's Avatar
Default Re: (SlepT ej6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlepT ej6 &raquo;</TD></TR><TR><TD CLASS="quote">the vin # on the motor will only match the vin # on the car if that motor came stock in that car, if it was swapped into it, it will not match!</TD></TR></TABLE>
thats pretty obvious
Old Jan 26, 2004 | 09:34 AM
Nextelbuddy's Avatar
Default Re: (silverEH2)
if the motors dont have vins on the tranny or the block and its not a jdm motor then it could quite possibly ne a 94-95 obd1 motor. all pre 96 motors did not come with vins on the motors or the trannies. so dont automatically assume its stolen unless you see blatent shaving marks or scarred areas by where the VIN should be. basically on 94-95 gsr motors and 94-55 delsol b16 motors instead of the VIN plate being on teh tranyn and block you should see 2 little holes there and no plate.
astig* DC2
Sep 21, 2006 10:29 PM
civicsareslow
Jun 1, 2005 01:22 AM
gaydm.accord
Feb 24, 2004 02:41 PM
fcuked
32
Nov 29, 2003 01:17 PM
BeanRacer
Apr 16, 2003 07:51 PM
