consume too much oil...
Old Jan 25, 2004 | 11:58 AM
lakerschamp2000's Avatar
Default consume too much oil...
my 98 luse has only 80K miles and the motor consume too much oil. there's no oil leaking anywhere, there's some smoke when warm up in the morning but once it's warm, no more smoke. does anyone know what is wrong?
Old Jan 25, 2004 | 12:02 PM
Matgallis's Avatar
Default Re: consume too much oil... (lakerschamp2000)
it's probaly normal. If ur in vtec a lot then your going to eat oil.
Old Jan 25, 2004 | 12:34 PM
Default Re: consume too much oil... (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">it's probaly normal. If ur in vtec a lot then your going to eat oil.</TD></TR></TABLE>
if vtec consume that much oil, then it would never been built.
I am talking about 1 quart of oil per week.
Old Jan 25, 2004 | 12:38 PM
hondatim's Avatar
no, not normal.
I'd suggest performing dry and wet compression test and seeing what your results are.
Could be rings, valve seals, cylinder walls, etc.
The compression test would be a good place to start though.
Shakes's Avatar
space cadet
check your cam seals, valve cover gasket, all that stuff.
your not seeing ANY oil anywhere?
Old Jan 25, 2004 | 07:30 PM
IhAvEaLuDe's Avatar
i have the same problem, but i do use v-tec alot..just dropped my built engine in 3 weeks ago.... i dunno bout 1 quart a week, but it eats alot.. my engine is brand new too.. sucks.
Old Jan 26, 2004 | 07:50 AM
577HondaPrelude's Avatar
Default Re: (IhAvEaLuDe)
I would do a compression check, and also replace the PCV valve, then go from there.
Old Jan 26, 2004 | 09:12 AM
Timmy Joe's Avatar
I also have the exact same issue. When I vtec all the time I go through about a quart a week and honda says its normal? I dont think so. There are guys on here with turbo ludes and engines that are built that dont burn a drop.
And of all people they should be burning oil.
Old Jan 26, 2004 | 05:53 PM
tomtom211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IhAvEaLuDe &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem, but i do use v-tec alot..just dropped my built engine in 3 weeks ago.... i dunno bout 1 quart a week, but it eats alot.. my engine is brand new too.. sucks.</TD></TR></TABLE>
should you be driving that hard on a freshly built motor?
ohh, and mine drinks alot of oil too. I think maybe my rings are going bad. Need a compression test bad.
sepulchral
Mar 26, 2006 04:36 PM
Jeff
Apr 18, 2005 06:23 AM
bigslimdog
42
Mar 27, 2004 03:02 PM
Accel Junky
Apr 28, 2003 02:18 PM
customx_
Mar 18, 2003 05:56 AM
